| Chip Amps Amplifiers based on integrated circuits |
Dear all,
recently, i've built a gainclone based on an lm1876, as suggested in the datasheet. it seems to work fine, apart from one strange problem: when I plug in my laptop, i notice an audible, though not very loud 50Hz-hum. as soon as I unplug the laptop from the amplifier, the amp is dead quiet, with no audible hum at all. The laptop plugged in my faithful old denon-amp doesn't hum at all. Of course i'm using shielded cable. Does anybody have an idea? Should I disconnect the grounded shield from the cable on the amp side? But in this case, i would lose the reference, wouldn't I? I'm thankful for any advice! |
#2 |
Ground must go from source to the amp.
But if there is a plus shielding wich is also connected to the ground, then you could try to disconnect it. Or the earth from the amp. Whats earthed in your system ? |
#3 |
i guess that the laptop is earthed somehow - i'm not sure about that.
my amplifier - ehm, good question. it's not in an enclosure, and the ground reference is the middle of the two secondaries on the transformer. could be that the amp is floating but then - it should be grounded via the connection to the laptop. anyway - i'll ground the amp and see if the problem is gone then. |
| Dual-mono chipamp (3886) problem - possible grounding issue | phresh | Chip Amps | 31 | 29th February 2008 03:50 PM |
| Another grounding issue | marcus7601 | Chip Amps | 3 | 20th February 2007 03:34 PM |
| Please help.... Grounding issue, and 60 Hz hum | PaulHilgeman | Parts | 25 | 27th November 2004 10:30 PM |
| Another PS and grounding issue | sam9 | Solid State | 4 | 13th September 2003 12:07 AM |
| Page generated in 0.09457 seconds (54.63% PHP - 45.37% MySQL) with 10 queries |
