Old 2nd May 2006, 11:37 AM   #1
Mrpong is offline Mrpong  Thailand
Default Need help: Look for bridged LM3875TF schematic
I'm looking for a simple schematic using LM3875TF in bridge mode with Burrbrown DRV134.
Thank a lot.
Old 3rd May 2006, 12:14 AM   #2
Default LM 3875 schematic
This should work for you.Click the image to open in full size.
Old 3rd May 2006, 02:24 AM   #3
Thank you so much. May I ask certain questions?
- How important are the components marked as "Optional"?
- Which roles do these optional components play in this schematic?
- For C1 (1uF), I think it's a coupling cap. If my memory is correct, a regular inverted shematic (non-bridged) uses 2.2uf or 3.3uf. Can we use 2.2 or 3.3?
Old 3rd May 2006, 06:14 AM   #4
Default Pa 100
C-1 is the input cap, to block DC offset from pre-amp, 1 uf is a round figure with the 1K, 22K, 220pf to produce a flat frequency response from 5hz to 35khz. If you are positive about your pre-amps output and C3 and C4 are used then you can leave out the input cap.
C3 and C4 are used on the sense leads of the DRV134 to prevent DC offset, these caps if used must be high quality metal poly film types.
C13 and C14 can be left out, use them if you have severe RF conditions i.e.5000watt radio station next door.
L1 and L2 are inductors made from 10 turns of #20 magnet wire on the body of the 2watt 10ohm resistor.
C11 and C12 are the negative feedback caps, these can be left out if the amps DC offset is OK. If they are used I prefer High quality 5% tolerance 16V tantalums or deposited silver micas, polorized.
The 220 pf cap should be a silver mica.
DRIVE ONLY AN 8 OHM LOAD with this amp even at 25VDC+/-, it will give you about 100watts into an 8 ohm load. Good Luck
PS layout is critical use a ground plane keep the NFB loop as close to the chip as possible.
10 x LM3875TF want to be used delicateear Swap Meet 1 24th April 2008 06:58 PM
I would like to have LM3875 bridged, do you have schematic? destroyer X Chip Amps 7 15th September 2006 07:24 AM
Lm3875TF+LM3886TF ANTHONY2181 Swap Meet 4 13th August 2006 08:32 PM
LM3875TF source in / near UK etc urxle Chip Amps 11 14th July 2004 12:08 PM
lm3875t? or lm3875tf karma Chip Amps 36 25th May 2004 07:03 AM
Page generated in 0.10969 seconds (59.83% PHP - 40.17% MySQL) with 10 queries
