Old 30th April 2006, 01:06 AM   #1
Default lm4780 bridge pcb layout
first one i made. transfer one side and drill 2 component holes to line up on. touch up holes with a majic marker. deburr holes on other side. aline transfer with holes and etch. the caps you can raise off the board a 1/8 inch or so to solder under them where the traces meet top and bottom. wont hurt a thing .solder a wire in the hole where the chips heatsink will be to connect top and bottom trace there as well. schematic is on the chips data sheet.
you will need to solder some on top of the chips pins as well. it is
best to just put the chip into the board not too deep so the straight part of the pins are showing on top to aid in soldering
Old 30th April 2006, 03:23 PM   #2
Default solder side pcb
here is the solder side
Old 30th April 2006, 03:23 PM   #3
Default component layout
parts placement refer to the lm4780 data sheet
Old 9th May 2006, 02:35 PM   #4
kalmara is offline kalmara  Bulgaria
kalmara's Avatar
Arent the IC's too close to each other, can it coll normal ? ? ?
Insane HONDA FAN !!! Variable Valve Timing and Lift Electronic Control equals....HIGH ADRENALINE !
Old 11th May 2006, 07:00 AM   #5
1000W is offline 1000W  India
dgaxeman,
Can you post the eagle files? Also whats the size of the PCB?
-MP
Old 14th May 2006, 07:07 PM   #6
Default eagle files
i use ivex windraft and winboard not sure if you can transfer these to eagle
Old 15th May 2006, 06:28 AM   #7
Is there an eval of this s/w somewhere?
Old 15th May 2006, 02:10 PM   #8
jackinnj's Avatar
this works:
the Gerbers can be found on the AudioXpress website --
LM4780 pcb layout and others BrianGT Chip Amps 263 12th January 2008 11:26 PM
Another layout of LM4780 cccp Chip Amps 7 15th February 2005 05:25 PM
Page generated in 0.10910 seconds (58.08% PHP - 41.92% MySQL) with 11 queries
