Some more 3886 questions...
Old 29th April 2006, 06:13 PM   #1
Bassterror is offline Bassterror  Germany
Default Some more 3886 questions...
Perhaps you can give my another little help:
1.
I want to use a single big toroid for 4, maybe 5 lm3886.
I'm going to start with 2200F (+&- each) soldered directly at the pins.
If I understood these snubber theories, the transformer and the capacitors form an oszillating circuit. All people recommend not to use more capacitance because of that.
But in my case, the transformer will "see" 22.000F of all ics.
What will happen?
Better use 5 small transformers?
2.
If I decide to big capacitors with snubbers later, wich disign is the best?
Mayby a stupid question, but there has been written so much that it's hard to find the optimun for a newbie...
I do not want to use more than 10.000F-15.000F (+&- each) per IC.
3.
Many chipamp disigns use 8 diodes for rectifying. Has that any
advantages compared to the classic rectifyer disign with 4 diodes and the low ends of the transformers secondary windings directly to the circuits ground?
Thanks,
Stephan
Old 29th April 2006, 07:43 PM   #2
CJ900RR is offline CJ900RR  Sweden
1. The cap's are (should be) in paralell so 1 circut cant "see" all cap's. It can only "see" the one in front of it. The current doesnt go in the cap and back out again so to say.
I have read about the snubber's and personaly i dont feel the need to use it. I have a setup of one toroid, then three (3) 22000uF cap's/voltage channel and on the pcb i have one 2200uF/voltage channel. And that is more then enough. The bass is tight and fast and it stores enough current for my 2 pcb's with LM3886 on so they can continue playing for about 20 secconds after i have taken the plug out of the walljack.
You shouldnt be needing 5 transformer, just one big with alot of VA, maybe 500 or 600?
2. Well... i started with only one toroid and after that one 10 000uF onboard/voltage channel. It's really a matter of taste. If you use to small cap's you want get enough bass, and if you use to big you get bass, but it can be slow.
3. Dont know about this one, i use 2 classic rectifyer's.
Old 30th April 2006, 04:45 AM   #3
! is offline !  United States
Default Re: Some more 3886 questions...
1.
Maybe? It would be good to nail-down the needed current drive for your speakers and THEN, process with what it'll take to get there.
Not quite, the higher inductance but it's additive, you can parallel caps to improve this, but it "might" cause oscillations. Remember that if one single person out of 1000 has oscillations, then doing something that "might" have caused it, becomes the voodoo child for everyone. (Gotta luv Jimi). You can use more capacitance but don't use ONLY very high mfd, large caps. Put some reasonably small caps close to the chipamp, but larger than the domain of film or ceramic ~ < 5uF (in cost effective sizes) realm.
What will happen?
What'll happen is that with loud volume and high bass, there is the possibilty that current will backflow from the caps local to another channel, to those on the channel playing that loud low bass note. However, 22,000 uF is nothing to sneeze at, I have a chipamp with about 50% more capacitance that plays for about 4 seconds after the AC power cord is pulled from the wall, at fairly high volume. In other words, I suspect with 22,000 mfd you are in a safe region so long as all those caps have a low impedance path to each other. IE- thick traces or heavy gauge wiring.
You could, and it might be slightly better channel separation, but that's pretty messy for a layout, if you were considering an unregulated PSU, I'd just go regulated before I'd do that... not to knock the idea, it'd work, but that's a ton of real-estate and cost with questionable benefit.
2.
There are as many designs as builders, better to mention what you are contrasting. With 5 chipamps, 10K mds per rail is enough, probably even overkill with low impedance between each. It's not that I'm trying to discourage you from 10K mfd per, just providing a point of reference that it's enough given a good layout.
3.
Thanks,
Stephan
You will find people that swear they hear a difference, but I suspect it's only making up for other deficiencies in the amp. Even so, 5 chipamps is a non-trivial amount of current if you use fewer trannies, do the math and figure out if the target configuration is within the peak current capabilities of the diodes you choose (keeping in mind that for most higher-current diodoes, you need a 'sink on them to reach the rated current for a sustained period of time to remote that heat which you can also calculate.
Old 1st May 2006, 12:05 PM   #4
thanks for your replies
I think I just try it with 2200F Panasonic FCs i've already got here,
and maybe add some more later.
Whould using an rectifyer for every chip solve that problem?
I just got a big bag of mur860 via ebay.
Old 1st May 2006, 12:59 PM   #5
Yes that would prevent it from happening but it's not necessarily a problem, is a trade-off but possibly a positive thing if you want to limit the amount of capacitance, to have the entire load buffered by more than one pair. This is a big project though, are you sure you want to only stick with some 2200 caps you already had? Might want to get 4 x 10K mfd or so for a centralized reserve right after the rectifiers then the 2200 mfd pairs closer to each chipamp. It depends on how loud you want it though, 5 x chipamps is a lot of volume for some situations if building for max power. If it'll never be at max power (for certain) you dont' have to design for that.
Old 1st May 2006, 01:34 PM   #6
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Default Re: Re: Some more 3886 questions...
One person out of 1000 has an oscilloscope and enough patience to use it to check that everything works as expected.
The rest just rely on popular wisdom...
I use to feel like the small child in The Emperor's New Clothes tale
Some more 3886 questions...Hide this!Advertise here!
lm 3886 larryg Chip Amps 6 1st June 2009 06:38 PM
Using +/-70V on a LM 3886 Pery Chip Amps 17 23rd July 2007 09:58 PM
Noisy 3886 jumpus Chip Amps 36 2nd July 2007 04:20 PM
pre amp for 3886 bostonswoop Chip Amps 6 19th June 2006 02:58 PM
Impressions of Snubbered BrianGT 3886 vs Reg 3886 moving_electron Chip Amps 1 23rd March 2005 06:51 AM
