| Chip Amps Amplifiers based on integrated circuits |
Hello all,
I was trying to throw together a 3886 single sided PCB I got one built and it had a case of the hums, what's worse is I had no huming when I had it on the breadboard, how annoying. A little redesign later and I've got this. I was wondering if anyone could give me some sugestions. Nothing special going on. It's pretty much just the reference design. I'm cheap but open to suggestions. thanks! --Jason |
#2 |
Wondering how are your grounds connected together???
#3 | |
Agreed^, You have some ground problems and a missing point for the speaker ground. |
#4 |
well I'm kind of new at this so what I did is I decided to keep the two grounds separate and run a wire for each one. Is this a bad idea? I just ran the grounds to a star ground.
I ended up modifying a bit before I actually built one. I changed the 100uf caps to 1000uf and widened the space between the 1000uf and the .1uf caps, plus a little other clean ups. I built one and it seems to be working fine to me, I even ran it through a 12 inch sub I had laying around it worked fine to me. Now I suppose does anyone of you gainclone gurus have a beef with this design? --Jason |
#5 |
You should pay attention to the NC (No Connection) pins.
Can you upload the Schematic ? It seems strange
If you want power you must add control |
| Single sided PCB for Zen v4 | kirc | Pass Labs | 59 | 3rd May 2012 11:29 AM |
| Single sided GC | DragonMaster | Chip Amps | 16 | 9th April 2006 08:50 PM |
| 50 watts more, single sided? | psychosteve | Chip Amps | 4 | 14th September 2004 04:35 PM |
| Single Sided PCB for Zen V4 | GeorgeBoles | Pass Labs | 0 | 29th August 2004 12:55 AM |
| Single sided PCb for lm4780 | rs1026 | Chip Amps | 11 | 22nd August 2004 09:16 PM |
| Page generated in 0.15992 seconds (42.79% PHP - 57.21% MySQL) with 11 queries |
