| Chip Amps Amplifiers based on integrated circuits |
Hello all,
I have a quad 34 preamp thats been to an ingenieur in Holland to replace the opamps.They have been replaced by the OPA134 or OPA2134. I also have a quad 405-2 who had the opamps replaced by bb 134 When i got the set back i started listening. It sounded terrible.The high tones were not nice to listen. I changed the opamps in the 405 back to the tlo71 and also put in the ne 5534 and the sound was a lot better.With both of these opamps. I think the bb 134 had oscillation...I am not an elektronic expert so i dont know for sure. But i am not happy after all.The sound is still to sharp.My old marantz preamp (1976 ) sound better then the quad 34... So now i want to change the opamps back in the quad 34. Should i do that with the ne series 5534/32/33? Or the new tl2071 series? Or stick with the old tl071? I have 8 tl071cp and 4 tl072cp they were in the quad 34 officially. Can someone help me and tell me which opamps i have to get? A replacement for the tl071 and a replacement for the 072cp? |
#2 |
Nobody?
Then i just put the tl071 back in the preamp. I dont like the high treble that comes out off the set. Its no fun to listen to. Is it possibel to place the ne 553xx series in the preamp? Anyone here ever serviced a quad 405 or 34/44 preamp? Regards, Tony |
#3 |
Electrons are yellow and more is better!
Maybe you are not used to how modern opamps sound like but it may also be the case that the OPA134 didn't have optimal wokring conditions.
Personally I think OPA134 is excellent in many places.
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
I don't want to offend you and I also don't know what your source and speakers are but, maybe it is now more precise and it reveals the flaws of the source.....If it is the case you can borrow a better source and try again with the OPA134.
Just trying to help.... |
#5 |
The newer op amps have quite a lot more bandwith. it could be they are oscillating if the quad was designed for TLO71
#6 |
OPA134 and TL071 are smiliar in speed so I on't think there will not be any stability problems but OPA134 maybe emphasize other shortcomings.
#7 |
Okay , guys.
Thanks first for you reply`s. Maybe it is that i am not used to the new opamps. I am going to listen to some more recordings and decide then what i am going to do. Everyone i am asking for the advice is very enthousiastic about the bb opamps so i ll give it a try. Regards, Tony |
#8 |
Did you also have the large number of electrolytic capacitors in the signal path replaced, these deteriorate with age and ultimatly leak causing damage to the PCB
Stuart |
#9 |
Hello, Stuart.
Thx for your advice. The ingenieur here in holland also changed the capacitors. He replaced everything thats aged. I have listened the 405-2 with another preamp. A marantz. Now i am sure.I am going to replace the opamps back in the 34. I dont like the harsh sound at all. Maybe its just my ears... Regards, Tony |
#10 |
I have rebuilt a large number of 34s and 405s using OPA134s this was the comment from the last customer
Hi, Fired up the amps this morning. They sound fantastic, they're not really warmed up yet either. Great clarity and weight without a hint of harshness. You were right, they work well with the quad speakers. Thanks again, good doing business with you, Cheers, Gordon So I am surprised that you have problems with them. If you replace the opamp in the 405 with the original you may have to replace the capacitor between pins 1 & 8 as it is not required for the OPA134 but may be necessary with the TL071 or LM301 in the 405 Stuart |
| Back to Back transformers and safety ground | dsavitsk | Tubes / Valves | 1 | 9th February 2009 10:10 PM |
| back to back coupling capacitors | reddog | Solid State | 5 | 3rd January 2006 06:59 AM |
| (Attn Planet 10!) active xo & 2.5 way back to back Vifa P13 mids - questions | paulspencer | Multi-Way | 9 | 15th August 2004 05:34 AM |
| Back to Back Polarized Electro's | EchoWars | Solid State | 11 | 15th November 2003 09:30 PM |
| Back to Back input diodes | Kevin McCready | Solid State | 0 | 9th September 2002 11:56 PM |
| Page generated in 0.14282 seconds (63.10% PHP - 36.90% MySQL) with 10 queries |
