Old 25th April 2006, 07:41 PM   #1
Default LM3875 rail voltage question
First of all, sorry if this has been covered before. I've done a few searches and can't find a definitive answer.
I've started putting together my first GC monoblocks based on Peter Daniel's LM3875 boards but I've run across a problem with my power supply. I was planning on using Noratel 120VA 2x25V toroids (230V AC) from http://www.farnell.co.uk (part no 9532358). The problem is that I've found I'm getting around 29V AC from the toroid (with the outlet power measured at about 243V AC) which is giving me around ±40V DC at the rails after rectification (again, using Peter Daniel boards).
Is this too much for the LM3875 or does this depend on other factors?
For cooling I'm planning on using an open-ended aluminum enclosure, with the chip mounted to a piece of alloy bar attached directly to the wall of the enclosure.
Any help is much appreciated.
Greg
Old 25th April 2006, 09:13 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
2 x 29 VAC unloaded is OK.
/Per-Anders (my first name) or P-A as my friends call me
Old 25th April 2006, 09:34 PM   #3
Thanks Per-Anders. Is it likely to drop when the amp's loaded?
In theory UK mains power should be 230VAC. My main concern is that if it gets much higher I may go over ±42VDC which is (as far as I know) the absolute maximum the LM3875 can handle.
rail voltage mike49504 Car Audio 3 11th November 2008 06:12 PM
Rail Voltage to Capacitor Voltage Mermprin Parts 6 20th September 2004 03:56 PM
Power transistor rail voltage question yeshu26 Solid State 23 21st July 2004 06:46 PM
Rail Voltage Failure Question thylantyr Solid State 2 26th March 2003 09:40 AM
Rail voltage compared to transformer voltage SteveG Solid State 4 22nd July 2002 11:50 PM
Page generated in 0.09534 seconds (61.72% PHP - 38.28% MySQL) with 10 queries
