| Chip Amps Amplifiers based on integrated circuits |
Okay, so I've had a few of Peter Daniel's gainclone kits running for a few months now, and I can't get rid of the hum. It's definately audible through the speaker from the listening position when no source is connected to the amp and gets slightly louder when I connect a source. I've tried rewiring it a couple times now, and I've got it at it's quietest, but I still consider it unacceptable (compared to my Denon receiver hooked up in the same room to the same source and speakers which has no hum unless you have your ear right up the driver and even then, basically negligable).
So I'd like some help in troubleshooting this. I have a theoretical background in electronics, but this is the first amp I've built. I've made a diagram showing how I've wired things. I'll take a picture of the actual construction later if need. I built it on a piece of MDF for now. The first time I used strainded hookup wire, and the newest hookup revision I've used solid core copper. The chips are mounted to heatsinks using mica/thermal compound. You can consider my mains "poor" as the electricity in my neighbourhood is pretty dirty, and the wiring in my house is equally poor, but as noted my Denon amp runs fine. Suggestions!?!? -Scott |
#2 |
the forum is saying my image has errors, just trying to upload it again.
-Scott |
#3 |
Look how the high current wires are so close to each other, not forming a great loop.
And not just the rails, but also the speaker wires are close to the rails, and to each other. The signal should go from the RCA directly to the PCB and just after that to the MAIN GND ! Keep the wires really close to each other, and the signal wires far as possible from high currents. With a layout like this you shouldnt get any hum, I promise ! ![]() But if this doesnt solve your humm, you have something other problem wich doesnt appear on yourt drawing, like wirings between to two amps, or with using the safety earth a wrong way, or inappropriate shielding, etc. Good luck ! |
#4 |
You are missing a connection to earth. Connect the house safety earth wire to the chassis. If you transformer has a metal case also connect this to ground Then connect the PG+ and PG- to that connection. That should take care of the hum.
To test: short the input. You should only hear a quiet hiss which is the residual noise of the system. Try hooking up a battery powered CD player. You should not have any hum. The try a mains CD player. If you have now have hum you have a earth loop. See the article on earthing at http://sound.westhost.com/ Computer audio has an inherently noisy ground. This creates other issures. But that is another thread. |
#5 |
I thought it's OK to isolate the safety earth from the circuit ground?
In any case, check whether the RCA body is touching the chassis. If both RCA body touching, it may form a grd loop |
#6 |
If you have audiosector-pcb, signal-ground(sg) and output-ground(og) are connected at the pcb.If you run wires like in your drawing you are causing groundloop by connecting those two at your wiring-terminal.try running shielded wire from rca-input to sg at pcb and in at pcb.
Klaas |
#7 |
Fossil, I think that what is meant by an "isolated ground" is one which the chassis ground and circuit are separated by a ground breaker (resistor and capictor).
The circuit ground needs to be referred to earth otherwise it will float. |
#8 |
Thanks for the replies everyone. I think my RCA's may not be properly isolated from the chassis. I'll try reworking that, as well as seperating in-gnd and o-gnd from the terminal block.
-Scott |
#9 | |
#10 |
Assuming the ground floats halfway between V+ & V-. any difference between V+ & V- will be amplified at the output. I'll try to simulate this evening (USA EDT).
| What case is this? | lanierb | Class D | 2 | 4th January 2007 10:14 PM |
| Gainclone in a Hammond 1455 case | hifi | Chip Amps | 19 | 22nd September 2004 09:49 PM |
| What to use for a case ???? | la9 | Chip Amps | 3 | 22nd August 2004 03:34 AM |
| DIY Case | dhole | Pass Labs | 9 | 15th August 2004 02:47 PM |
| case | theChris | Parts | 2 | 8th February 2003 08:08 PM |
| Page generated in 0.13936 seconds (69.62% PHP - 30.38% MySQL) with 11 queries |
