| Chip Amps Amplifiers based on integrated circuits |
Audio Junkie
I am just starting to get into these chip amps. I have an application where i want to use them. My BMW Stock amplifier uses 10 amplifier channels on 5 chip amps running from the 12V supply, no switcher inside. I am wanting to rebuild something similar using LM3886 amps.
What sort of current is required for these amps under full power @ 4 ohms??? I need to find or build power supply for the project. Dave |
#2 |
these chips are rated at about 11A if memory serves correctly...
#3 |
If I did the math right,I think it is 5.8A
checkout datesheet page 20 |
#4 |
Your best bet is to get the Overture design spreadsheet and play about. It shows current demands among other things like heatsinks, fb resistors & stuff.
#5 |
68W over 4 ohms at 28V...7A
50W over 8 ohms at 35V...4.4A This however not the max rateing of the chip MAX output current limit will be between 7 and 11.5A difering from chip to chip |
#6 |
The current will not be an issue, you will have to make a swtich mode supply to get the voltage up from +12V to something more usable like +/-30VDC. At the 12V from the car battery you will have to have one non-inverted single ended chip and an inverted single ended chip bridged then you will get a 24 volt swing minus loss, for about 18 to 22 watts +or- alittle. You would probably be better of with the orignal TDA chips already built............
| LM3886 Pin7(gnd) current? | Arx | Chip Amps | 14 | 18th July 2007 02:51 PM |
| LM3886 Current needs. | svbear | Chip Amps | 13 | 29th April 2007 08:11 PM |
| LM3886 Max Current | thomasfw | Chip Amps | 1 | 24th May 2005 07:03 AM |
| LM3886 Quiescent current | NITRO | Chip Amps | 4 | 20th April 2005 10:06 PM |
| lm3886 current at pin 8 | jaudio | Chip Amps | 3 | 29th December 2004 09:59 AM |
| Page generated in 0.15528 seconds (43.27% PHP - 56.73% MySQL) with 10 queries |
