Lm4780 SS PCB
Lm4780 SS PCB
Old 17th February 2012, 08:49 AM   #71
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Lm4780 SS PCB
Glad to help.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 26th February 2012, 11:05 PM   #72
tesla017 is offline tesla017  Serbia
Lm4780 SS PCB
Default info
Hello from Serbia
I want to build this revision of chip amp. Special tnx to pinkmouse for nice revision of PCB. I want to build Stereo Amp so here I am
I mark all components to the sch file so if someone who build can tell me are this is ok?
One more question, why are PGND1, PGND2 separated from GND, SG1, SG2, CHGND, OG1 and OG2 ?
Thanks for all.
Old 26th February 2012, 11:49 PM   #73
Lm4780 SS PCB
Larger image:
http://www.dodaj.rs/f/1R/Eo/3HPHPbMo/1/sch.png
Old 26th February 2012, 11:50 PM   #74
Lm4780 SS PCB
Default Smallsized image
Sorry for small image in previus post:
Old 27th February 2012, 01:25 AM   #75
blueskynis is offline blueskynis  Serbia
blueskynis's Avatar
Lm4780 SS PCB
Hi tesla017,
you have some major errors in your posted schematic. Please look more carefully at LM4780 datasheet.
Windows-free with Linux
Old 27th February 2012, 01:38 AM   #76
Lm4780 SS PCB
Default Hello
blueskynis tnx for fast replay
All this values of components I take from here:
http://www.unisonus.com/pl/p/file/c6...80_PCB_sch.pdf
I download data sheet, witch schematic i shoud watch...All schematic are difrent than pinkmouse version. I see that mute function is using like soft start the values are 8K2 and 15K resistors and 10uF. What else is wrong?
Old 27th February 2012, 09:09 AM   #77
pinkmouse's Avatar
Lm4780 SS PCB
Originally Posted by blueskynis View Post
Hi tesla017,
I don't think so, my circuit is an exact copy of the datasheet, (apart from component values that I explained on the first page) and works well. Can you explain further?
Old 27th February 2012, 09:16 AM   #78
pinkmouse's Avatar
Lm4780 SS PCB
Originally Posted by tesla017 View Post
One more question, why are PGND1, PGND2 separated from GND, SG1, SG2, CHGND, OG1 and OG2 ?.
Hi Tesla. That's just a workaround to aid laying out a star ground, if you look at the pcb you can see what I mean. As for component values, they are all on the datasheet, the standard stereo layout. You may have to recalculate the soft start values for your voltage rails, but that data is given in the datasheet as well.
Old 27th February 2012, 09:27 AM   #79
pinkmouse's Avatar
Lm4780 SS PCB
Oops, it looks like the datasheet has been revised since I did this layout. I'll try and find an old copy that I worked from, that should clarify matters.
edit: Right, I can't find an old copy of the datasheet, but as my work was based on that of Brian and Peter, you can use the schematic from the Audiosector website for component values.
Old 27th February 2012, 10:06 AM   #80
blueskynis's Avatar
Lm4780 SS PCB
  • Rz1 and Rz2 should be 2R7 ohms, not 22k
  • R1 and R2 should be 22k, not 2R7 ohms.
@pinkmouse
I was commeting on his schematic not yours. Your schematic is in accordance with the datasheet.
Lm4780 SS PCBHide this!Advertise here!
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 01:37 PM
LM4780 from who? jarre Chip Amps 6 10th August 2006 08:04 AM
lm4780 p/s j9184p Power Supplies 4 28th June 2006 05:18 PM
anybody tried a LM4780? travis Chip Amps 162 23rd March 2005 09:14 PM
lm4780 odysseybmx414 Chip Amps 2 22nd February 2005 07:13 AM
Copyright ©1999-2017 diyAudio
