Old 26th January 2011, 05:58 PM   #61
pinkmouse's Avatar
Originally Posted by superR View Post
I today verified that pinkmouse's design still works
Good, I need to build a couple more.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 26th January 2011, 06:09 PM   #62
leadbelly's Avatar
So, at the risk of asking a question that been asked tons of times and on an old thread to boot: what can I do with the Eagle files? Does the free version of Eagle allow you to import them and modify? Does it allow you make the Gerber files with it? Can you import Eagle into some of the other free PCB software?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 26th January 2011, 06:13 PM   #63
pinkmouse's Avatar
Whatever you want, yes, yes, don't know, (I only have Eagle and Protel and they don't play together, others may).
Al
Old 26th January 2011, 07:26 PM   #64
superR is offline superR  Netherlands
If you are interested in the "ready to etch" pdf's I can upload those for you. It is a basic application of the LM4780 but it seems to work well. Pinkmouse, what is your exoerience with the zobel resistor and cap? I have not used it since I did not have the parts. If you can convince me to use them, I will purchase the parts
Old 26th January 2011, 07:37 PM   #65
pinkmouse's Avatar
I used to live next door to the Crystal Palace TV transmitter, and had a few problems with noise getting back up the speaker lines with the NS chips, the Zobel sorted it, and I've since been putting it in by habit. You might not need it, but it doesn't hurt. Your call.
Al
Old 26th January 2011, 09:30 PM   #66
Hmmz, ok, what values do you use and what power rating? There is only one mentioning of some sort of protection circuit which uses 2.7ohm 2 watt and 100nf, is that right?
Old 26th January 2011, 09:49 PM   #67
pinkmouse's Avatar
Unless you want to dig into the maths and work out the exact corner frequency, 2.7 -10 ohm values are practical with your 100nF.
Al
Old 31st January 2011, 11:35 AM   #68
pinkmouse's Avatar
Afternoon folks, updated version is now attached. Layout and grounding improved, and dimensions reduced to fit my current application. As always, files in Eagle format, lines on top copper are jumpers. Enjoy.
Al
Old 17th February 2012, 03:23 AM   #69
yugaaa is offline yugaaa  India
Send a message via Yahoo to yugaaa
Default My LM4780
I tried pinkmouse pcb and it works . The Amp is super silent and yes , i used the component values from audiosector .Thanks to pinkmouse and Peter .
Old 17th February 2012, 03:30 AM   #70
GloBug is offline GloBug  Canada
Banned
Cool man!
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 12:37 PM
LM4780 from who? jarre Chip Amps 6 10th August 2006 07:04 AM
lm4780 p/s j9184p Power Supplies 4 28th June 2006 04:18 PM
anybody tried a LM4780? travis Chip Amps 162 23rd March 2005 08:14 PM
lm4780 odysseybmx414 Chip Amps 2 22nd February 2005 06:13 AM
Page generated in 0.17597 seconds (46.23% PHP - 53.77% MySQL) with 11 queries
