| Chip Amps Amplifiers based on integrated circuits |
#51 |
I've never bothered, I just use 5% for outputs
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#52 | ||
#53 |
so how important are the matching of the output resistors, should be as important as any?
#54 |
What's an output resistor?
#55 |
Refer sch at post #34
R11 and R12 are output resistors and u will use them for parallel mode operation only. If you want to make a stereo version do not install them. At no time u should connect all the 3 speakers even if it is shown. U either connect the middle only with R11 and R12 installed or connect the top and bottom speakers(Left and Right) without R11 and R12. Gajanan Phadte |
#56 | |
#57 |
Just making sure I got it right, the thing called "J" in the scheme is just a wire to connect the two sides if you wanna go parallel?
#58 |
Discussion of pirate SW removed to Texas
#59 |
Thanks pinkmouse
#60 |
I today verified that pinkmouse's design still works
Made a pcb and at first it didn't work. Turned out the chip/input-ground was not connected to the power supply ground. Maybe I did something wrong with the "ratnest" function but after connecting both power and signal ground, presto, music from my loudspeaker.I used no zobel due to the fact I didn't have the parts available. Other parts used; resistor between input and +in 1 k resistor between inout and gnd 20k feedback resistor 20k -in to gnd 1k mute resitors, 10k each mute elco 100uf psu elco (on pcb) 1000uf and 0.1uf http://www.zelfbouwaudio.nl/forum/do...5222&mode=view http://www.zelfbouwaudio.nl/forum/do...5223&mode=view |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 01:37 PM |
| LM4780 from who? | jarre | Chip Amps | 6 | 10th August 2006 08:04 AM |
| lm4780 p/s | j9184p | Power Supplies | 4 | 28th June 2006 05:18 PM |
| anybody tried a LM4780? | travis | Chip Amps | 162 | 23rd March 2005 09:14 PM |
| lm4780 | odysseybmx414 | Chip Amps | 2 | 22nd February 2005 07:13 AM |
| Page generated in 0.13575 seconds (85.26% PHP - 14.74% MySQL) with 11 queries |
