Old 7th December 2006, 12:41 PM   #41
dj_zibi is offline dj_zibi  Poland
pinkmouse I wants to make PCB under two LM4780. I. TWO lm4780 ( every parallel) I want to make in bridge version.
What about this do you think?
Old 7th December 2006, 03:04 PM   #42
pinkmouse's Avatar
I would be a bit wary about running the 4780 bridged if you want any real power out of it. At 4 Ohm it gets quite warm, and the package isn't as good as transfering heat as two 3866s. However, if you use a nice big heatsink, 30-35V rails max, and make sure it never drives less than an 8 Ohm speaker then you should be able to get away with it.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 7th December 2006, 05:51 PM   #43
In my amplifier. LM4780 in parallel version worked on power supply +-34V on 4R. It was OK. Radiator had 45-50 * C.
Old 11th December 2006, 12:13 PM   #44
dj_zibi: can you please post the eagle files for your board? I would be grateful!
Old 11th December 2006, 01:03 PM   #45
jaste is offline jaste  Sweden
Do all resistors have to be with 0.1% tollerence if you want to go parallel?
Old 11th December 2006, 01:12 PM   #46
pinkmouse's Avatar
It's best, but you don't have to buy them that way, get more than you need and you can match them with a DMM yourself.
Al
Old 11th December 2006, 02:00 PM   #47
true, I just hope my elcheapo DMM got a o,1% tolerence....
Old 11th December 2006, 02:58 PM   #48
It's not about absolute accuracy, rather the resolution. Even a cheap 3.5 digit dvm will measure 10K with 10 ohms resolution (10.00). Although there will always be +/-1 digit uncertainty. As a percentage, 10 ohms in 10,000 ohms is 0.1%
Measuring the low-value output resistors is another matter!
Re heat, I agree with PM. Better to bridge with two LM4780s, each running in parallel mode.
Old 11th December 2006, 03:05 PM   #49
CarlosT is offline CarlosT  United States
Da**! I've never seen .1% resistors...you guys sure you're not talking about 1%?
Old 11th December 2006, 03:11 PM   #50
So the low-value output resistor is hard to meashure, maybe I“ll get that one from 0.1% department rigth away tehn, or do the even exist in that tolerance?
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 01:37 PM
LM4780 from who? jarre Chip Amps 6 10th August 2006 08:04 AM
lm4780 p/s j9184p Power Supplies 4 28th June 2006 05:18 PM
anybody tried a LM4780? travis Chip Amps 162 23rd March 2005 09:14 PM
lm4780 odysseybmx414 Chip Amps 2 22nd February 2005 07:13 AM
Page generated in 0.11066 seconds (79.69% PHP - 20.31% MySQL) with 11 queries
