| Chip Amps Amplifiers based on integrated circuits |
#31 |
I changed PCB pinkmouse. PCB is universal. It works stereo and parallel.
#32 |
How about schematics?
#33 |
Schemaik is on WWW Peter Daniel. Schematik is universal. PCB is active in stereo and parallel.
#34 |
You can use this one Palesha:
LM4780 amp sch they are all standard LM4780 applications. If you want to use this amplifier in parallel mode - 0.1% resistors are needed. I prefer 47k/2k in feedback and active stage in front of it. |
#35 |
Thank u very much
#36 |
Anyone figured out what the values of the components need to be? It would be great if someone could! Thanks!
#37 | |
#38 |
It doesn't matter. Parallel amplifier can drive low impedance loads (4R is not a problem).
#39 |
I just use 5% resistors and trim the value of the 1K resistor on the channel with the highest gain by measuring the differential at the output,.
At say 15v RMS output I usually can get the differential to within 5-10mv with standard value resistor. If your trust your DVM, Test this from 20 to 20khz. I haven’t tried this but maybe a tiny 8ohm speaker between the outputs in the 1-8khz region you may be able to hear the differential? |
#40 | |
![]() Well done dj, now let's see some other versions.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 01:37 PM |
| LM4780 from who? | jarre | Chip Amps | 6 | 10th August 2006 08:04 AM |
| lm4780 p/s | j9184p | Power Supplies | 4 | 28th June 2006 05:18 PM |
| anybody tried a LM4780? | travis | Chip Amps | 162 | 23rd March 2005 09:14 PM |
| lm4780 | odysseybmx414 | Chip Amps | 2 | 22nd February 2005 07:13 AM |
| Page generated in 0.12100 seconds (77.79% PHP - 22.21% MySQL) with 11 queries |
