| Chip Amps Amplifiers based on integrated circuits |
#11 |
After a gentle reminder from Serge, here are the Eagle files.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#12 |
Thank you Pinkmouse. I appreciate it very much!!!
#13 |
Thank's alot
IC's are our friends |
#14 |
Oh, it's just crossed my mind that the component values on the schematic may be wrong or missing. I never put them in properly as it was for my use only, and I knew what they were!
#15 |
Thanks a lot !
#16 |
Thanks for sharing Pinkmouse.
#17 |
Tanks a lot for this contribution.
I try to make a pcb and you made it... it's good for me... lol But you have the same schematic of peter daniel here ? So with your pcb can I made parallel or stereo or bridged confguration? And have you insert a mute circuit? what's that? another input on the pcb? thanks you for a answer regards, aceditnanar
"if it were necessary to build asylums for the idiots, you imagine the size of the buildings" - TaisToi! (french movie) |
#18 |
Mine is designed for dual mono. It's that way, 'cos that's what I needed!
The schematic may look like Peter's, but has none of the optional other components for different configurations. You could bridge/parallel it if you wanted, but there are better PCB designs for that. Then again, you could just alter the Eagle files to do whatever you you wish. ![]() All the info on the muting is on the datasheet, you have read it, haven't you?
#19 |
thank you for this quick answer...
I suppose that the mute circuit is just a voltage with a resistance (? ohm?)? and a switch? You thinks that there are better PCBs for the bridge and parallel? the PCB of peter daniel make all mode, haven't it? and not your PCB? Sorry for my english.. regards, aceditnanar
#20 | |
My PCB was designed by me for a specific job. It was never supposed to be universal, and I just posted it here in case it was useful to anyone else. I have no intentions of spending more time changing it, but if anyone else wants to, then feel free. It would be a good learning experience.
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 01:37 PM |
| LM4780 from who? | jarre | Chip Amps | 6 | 10th August 2006 08:04 AM |
| lm4780 p/s | j9184p | Power Supplies | 4 | 28th June 2006 05:18 PM |
| anybody tried a LM4780? | travis | Chip Amps | 162 | 23rd March 2005 09:14 PM |
| lm4780 | odysseybmx414 | Chip Amps | 2 | 22nd February 2005 07:13 AM |
| Page generated in 0.10847 seconds (81.11% PHP - 18.89% MySQL) with 11 queries |
