| Chip Amps Amplifiers based on integrated circuits |
I am building Brian's LM3785 stereo kit (two amp boards, one power supply board). I will be using only four diodes and two capacitors on the power supply board because the amp will be powered by a CT transformer. My question is: Do I need the 0.1 uF Cz capacitor and 2.7 ohm Rz resistor on the amp board? Brian's PDF with information says that they are optional. Thanks, Alex |
#2 | |
diyAudio Moderator Emeritus
Best of luck with your project, -- Brian |
#3 |
I tested both with and without and have concluded that with the optional componets, bass response was improved.
Jim |
#4 |
Thanks guys. I can't wait till I am off work and can go back to the project.
Alex |
| Question about CT transformer and Brian's Rev C power supply board | maurycy | Chip Amps | 9 | 8th December 2009 09:21 AM |
| Question/s about passive crossover and components? | Toast_Master | Multi-Way | 24 | 23rd January 2008 07:09 AM |
| aleph5 components question | VanguardVillage | Pass Labs | 10 | 9th June 2005 02:29 PM |
| Thanks Brian... | mourip | Chip Amps | 1 | 21st November 2004 06:29 AM |
| AR.com Ed Frias DIY X-over components question. | ghick | Multi-Way | 0 | 26th February 2004 03:41 PM |
| Page generated in 0.09398 seconds (62.05% PHP - 37.95% MySQL) with 10 queries |
