| Chip Amps Amplifiers based on integrated circuits |
FIRST LAYOUT IF YOU SEE ANY NEEDED CHANGES PLEASE ADVISE
#2 |
new layout
#3 |
parts placement
#4 |
starting left to right at tx inputs.
1 uf 100v cko6 metal film caps (2) mur 860 diodes (8) 4k7 or 4.7 kohm 2watt metal oxide resistors koa speer(2) 4700 uf 50 volt radial caps xicon (4) 1000 uf 63 volts radial caps nichicon low impedance (2) 1 ohm 5 watt xicon radial power resistors cement filled (2) .12 uf cko6 100 volt metal film caps got all from mouser online |
#5 |
A schematic is always nice but it seems easy to follow. The ground cap leads might be a pain to solder without thermal reliefs around the pins
#6 |
here is the schematic my torrids have (2) secondaries and can run 15 volts or 30 volts per rail depending on how you connect them got these for 10 bucks apiece later i might go to higher volt torrids . will post the double sided pcb for a bridged lm4780 i made
#7 |
i love it when you dont get smoke! works fine, ran into a little tight space problem at the 4k7 2w resistors so i drilled 2 holes in the center of the ground plane, so much for planning ahead.tilted the recs back for clearance 1 pic explains it all!
| Single sided PCB for Zen v4 | kirc | Pass Labs | 59 | 3rd May 2012 11:29 AM |
| A good single sided PCB for bridged LM4780? | Ulew | Chip Amps | 54 | 25th October 2008 12:46 PM |
| LM4780 Bridged mode and single supply | ringo42 | Chip Amps | 1 | 12th July 2006 09:58 PM |
| Single sided PCb for lm4780 | rs1026 | Chip Amps | 11 | 22nd August 2004 09:16 PM |
| Page generated in 0.36144 seconds (21.59% PHP - 78.41% MySQL) with 11 queries |
