| Chip Amps Amplifiers based on integrated circuits |
hello all im just getting into the hole micro board thing and i need a little help.
i want to build an amp and i have the schematics but i dont know how to rearange it for a pcb. if someone can explain how to do it or help me make the pcb with traces like in pic. i plan on using Stripboard sence it looks easyer to me. here is the amp... http://www.redcircuits.com/Page2.htm thanks in advanced |
#2 |
Hi.
You can use a software to it. But I allways do it 'handmade'. Buy the component's, and a piece of PCB board. Then you make a piece of paper, to draw the pcb on. You can place eg. the transistor's, and make them make hole's in the paper, if you find it difficult to meassure the right distance's between the component-legs . Then you look at the diagram and draw the trace's (could take a long time).Doublecheck the trace's. When you finished this, you place the paper on top of the pcb, now you can make marks where the hole's should be. Then draw and etch the PCB.... good luck Jesper
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp. |
| Page generated in 0.08921 seconds (61.27% PHP - 38.73% MySQL) with 10 queries |
