Old 15th April 2006, 04:54 PM   #1
jp88 is offline jp88  United States
Default transformer question
I am planning on building a 3886 gainclone. I found a transformer I think may work. It came out of a phillips integrated system with a cd player, tpe deck and tuner. The amp was rated at 100 x 2 The transformer while hooked up in the unit measured abou 45 vac from each side to the center tap. Does this sound like it will work?
WHAT
____________
Old 15th April 2006, 11:44 PM   #2
Primoz is offline Primoz  Slovenia
Maximum voltage for LM3886 is 2x42Vdc
After rectifying with diodes and capacitors the DC voltage is 1.414 * AC voltage. In your case you would get around 2x 65V, which would destroy your chips
You need transformer with voltage 2x28V or less. I think the best choice is 2x24V
Old 16th April 2006, 01:00 AM   #3
how about if I paralleled the secondaries and didnt have a center tap? can this be done with briangt or peterdaniels power supply boards? This would give me 45vac total.
WHAT
____________
Old 16th April 2006, 11:35 AM   #4
Frosty is offline Frosty  Australia
hi this would work, only if u convert your amp module to work of a single supply rail. The best option would be to buy a rated transformer at 2x24V and use the 2x45 vac transformer for a future high power amp project
Transformer question? mcameron Parts 5 23rd January 2005 07:52 PM
transformer question xcortes Chip Amps 0 31st October 2004 05:04 AM
Transformer Question TunaFish Tubes / Valves 15 18th June 2004 11:20 PM
Transformer Question toque_101 Chip Amps 2 26th January 2004 05:21 AM
Page generated in 0.11970 seconds (53.69% PHP - 46.31% MySQL) with 10 queries
