Thought you all would like to see this. I bid on 6 at $1 each. Please don't overbid me!
http://cgi.ebay.com/Aluminum-Heat-S...868740030QQcategoryZ80149QQrdZ1QQcmdZViewItem
davidlzimmer said:Just curious. Any buyers?
I put in a bid on 10. Thanks for the heads up!
traw said:I actually bougoht 20 of them last auction he/she had. They are a little smallish, compared to others, but just about right for 1-2 chips at 35 volt rails. Also, they are new conditin, nice and clean.
Perhaps for +/- 28VDC, not +/- 35 VDC -- at least with the LM3886 -- take a look at the specification sheet.
I was thinking of making a 3886 sandwich. The holes in the heat sinks look symmetrical, so two of them could be bolted together around a chipamp device. It's worth a try...
If they're not symmetrical... then I will get out the drill.
davidlzimmer said:"Thermal impedance would appear to be ~5 C/W"
jackinnj,
Is that Good? I'm cluless on that stuff. How do they rank. Planing to use 1 each on LM4780 project.
think of thermal impedance as the "resistance" of heat transfer from the device to the air -- so a lower number is better. you can find how "low" a resistance is required from National's website, or the product folder for the LM4780 or LM3886 -- the amount of power which is dissipated as heat is the problem that the heatsink has to confront.
i have LM4780's -- two devices in bridge configuration-- two heatsinks -- made a tunnel out of a pair of heatsinks -- a small computer fan with reduced voltage draws some air across the heatsinks -- i can run a pair of them full tilt.
- Chip Amps
- Great deal on Heat Sinks!!!
