Old 12th April 2006, 06:10 PM   #1
Default Regulated PSU from Pedja
I just need some help about capacitor polarity on Pedja's circuit. Since the lower rail is -24V I'm a little bit confused about placing the capacitors correctly. I wonder if it's ok on the picture I attached.
The picture was taken from Pedja's page and I added some + signs where they (hopefully) should go.
-Marko
Old 12th April 2006, 06:39 PM   #2
Igla is offline Igla  Slovenia
Hi Marko !
You forgot to attach the picture.If you are talking about LM338 circuit;
the positive side of the circuit: capacitor + side should be on +24V and cpacitor - side on ground;
the negative side of the circuit : capacitors + should go to ground and capacitor - side to -24V.
Regards;
Matjaž
Old 12th April 2006, 07:15 PM   #3
Obviously the picture wasn't attached.
I've placed the caps in the same way as you said. I was a bit confused because a friend suggested it was opposite.
Hvala
-Marko
Old 13th April 2006, 07:25 AM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
if you are still confused, the ones on the negative regulator is the wrong way around...
also unless I'm way stoned, you are connecting the -24 to the +24V's ground rail...
Old 13th April 2006, 07:38 AM   #5
Greg Erskine's Avatar
hi mlampret,
The schematic in the first post looks fine to me. Have a look here for a comparison.
http://www.tcaas.btinternet.co.uk/jlhnewps.htm
regards
Greg Erskine
Old 13th April 2006, 07:52 AM   #6
Andypairo's Avatar
The only way to use positive regulators for both rails is to make 2 +24V regulators and to connect them in series, as it is done in the schematic.
You have 0, +24 and +48V.
Now call the +24 your GND and you have a split power supply
Don't try this unless you have 2 separate secondaries and bridges.
Nordic please smoke less
Cheers
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 13th April 2006, 09:53 AM   #7
I'm glad that I still know how to connect the caps correctly
Thanks for your help, guys.
Old 13th April 2006, 11:08 AM   #8
Nordic's Avatar
looked totaly weird there for a second.....
but it makes sense now...
Old 13th April 2006, 01:30 PM   #9
And you should put C3 and C4 directly to IC pins.
Old 13th April 2006, 03:03 PM   #10
Igla: you mean I should put C3 and C4 directly onto LM3886T pins?
I made the connections so that 2x4700uF caps, LM338, C3 and C4 and LM3886T are as close together as possible, while keeping the transformer away from the chips. And I'm planning to put the heatsinks between the transformer and the chips.
Pedja buffer question... again and again Dxvideo Chip Amps 0 18th June 2008 09:22 AM
Source For Pedja DAC Transformer? dantwomey Digital Source 8 29th August 2007 01:29 PM
FS: Pedja Rogic Rev.1 DAC, mostly propagated Strohmie Swap Meet 4 27th August 2007 07:49 PM
Pedja's Regulated PSU yuval Chip Amps 12 15th June 2004 10:42 AM
i ripped off pedja travis Chip Amps 11 10th August 2003 10:58 PM
Page generated in 0.14311 seconds (66.23% PHP - 33.77% MySQL) with 11 queries
