| Chip Amps Amplifiers based on integrated circuits |
What kind of wire (guage, etc) is best for connections between my rectifier board and my lm3875 board, and in fact everything else in that project? thanks
Ali B. |
#2 |
I would use generic stranded copper. Nothing fancy is needed, but pay attention to where you route the wires!! That will have a MUCH greater impact on how your amp sounds that any specialty wires.
David |
#3 |
I use Carol 18awg stranded copper.
Its inexpensive and well insulated. Not sure if you are using a kit or not, but Brian Bell (BrianGT) uses these wires and recomended them to me, they work perfectly with his kit. I originally bought Parts Express's hook up wire, but it didn't fit well because it is 16awg and the insulation was not as good. Josh |
#4 |
It is often stated that you need thicker and as short as possible wire from main filter caps to ICs.In my setup , i use approx 8-9 AWG wire.However , it is hard to solder.I think something between 14-15 AWG would be optimum. Other wires are not so important. |
#5 |
Something else I don;t see mentioned is thta it is often advantageous to use a thinner guage wire from the ground on your input to whereever it connects to...
#6 | |
| 22 AWG silver plated solid copper wire for speaker wire? | G | Full Range | 21 | 15th February 2009 09:32 PM |
| magnet wire (not sure of the term) used as chassis wire? | jarthel | Parts | 8 | 27th September 2006 09:50 PM |
| What kind of signal wire do you use in your DIY DAC or CDP? | MGH | Digital Source | 54 | 22nd April 2006 11:10 AM |
| What kind of wire is good for internal amp wiring? | Bricolo | Solid State | 25 | 9th December 2002 07:42 PM |
| What kind of wire for Super Leach amp | supernet | Everything Else | 1 | 11th May 2002 07:16 PM |
| Page generated in 0.21924 seconds (34.70% PHP - 65.30% MySQL) with 11 queries |
