Old 11th April 2006, 12:03 PM   #1
diarav is offline diarav  India
Default LM3886 on +/-42V
I purchased a 30-0-30 V Transformer to build the PSU and power the LM3886 power amp (yet to build) and now I realise that the output DC voltage will be 1.414 x 30 = ~ 42V. The LM3886 datasheet shows maximum rated input voltage to be |V+|+|V-| = 84 V which comes very close.
Has anyone tried to use the LM3886 at the voltage of +/- 42V ? Or should I cut of the voltage at about 35V?
Thanks in advance
Din
Old 11th April 2006, 12:20 PM   #2
edl is offline edl  Hungary
edl's Avatar
That's so risky. Mains can vary +10%, and then the rails will be 45-47V.
Anyway +/-42V is already too much!
You could try an STK IC.
Old 11th April 2006, 12:25 PM   #3
running the lm3886 at +-50V
Do a search for max supply voltage. A few people run lm3886 amp with +/- 42.
Old 11th April 2006, 01:28 PM   #4
Thanks for your responses.
Looks like it is safe to use the 3886 at about +/- 35V. Would it be safe to use a 35V zener diode? I am not very keen on spending more on regulator ICs if not really required.
Moderator:
Not sure if this post now belongs to the power supplies area.
Rgds
Din
Old 11th April 2006, 01:35 PM   #5
Our, just use an extra bridge (or even two!) on each channel...that will knock it down another 1.5 to 3 volts...
Old 11th April 2006, 01:44 PM   #6
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
If you would put 5 bridges in series you would end with ~35V dc.
Maybe its better to unwind some secondary windings , if you don't mind disassembling the trafo.It would be more rational.
Old 11th April 2006, 01:48 PM   #7
SteveMajerus:
Are you suggesting something as attached? (Sorry for the crude drawing, I used Microsoft PaintBrush).
Old 11th April 2006, 01:51 PM   #8
pinkmouse's Avatar
My LM4780 is running quite happily on 42V rails. You do need big heatsinks, and pay attention to thermal coupling as it does run fairly warm. It also sounds nicer than when it was running on lower rails.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 11th April 2006, 02:00 PM   #9
It may run for few years at higher rails , but may fail one day if mains voltage rises for 10%.
Also , Spike protection will surely activate when listening at highest levels , because the ICs internal power dissipation will be exceeded.
For 4 ohm loads , one should use ~30Vdc , and for 8 ohms 36V is ok.
Diarav : you got the idea right...
Old 11th April 2006, 02:06 PM   #10
demogorgon's Avatar
Send a message via MSN to demogorgon
I'v run the lm3886 on 50V rails, and it played, but was severely unstable, and when i pulled out a phonoplug, the chip blew.
i have altso tested the chips at 45-46V, and it ran without any problems at all. so in conclution, running the chips at maximum reccomended voltage, is not a problem. if you view the datasheet it altso says that maximum voltage the chip can handle in a non-playing envirement is 94 or 92V if i remember correct, and that allows for some margines. remember when power is pulled through your transformer voltages will sag.
-Marius
My First LM3886 GC samsagaz Chip Amps 49 29th June 2008 07:55 PM
Psu Lm3886 Mayday Chip Amps 29 29th April 2007 06:10 PM
Lm3886 Bpa Tombson Chip Amps 99 21st August 2006 12:04 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.76408 seconds (12.91% PHP - 87.09% MySQL) with 11 queries
