| Chip Amps Amplifiers based on integrated circuits |
I started this amp last Spring and only just got around to finishing it. The chassis is 1/4" aluminum, held together with stainless screws. The top and bottom panels are perforated aluminum and the side panels are cherry.
Silver-clad copper wire is used for the connections to the power supply board and to the speaker outputs with teflon spaghetti tubing from McMaster-Carr for insulation. The heat sink is made from a piece of titanium-clad copper buss bar, which I milled to remove the titanium on one side. I use a 10K Noble pot from Electronics Goldmine for volume control. I'm intending to use it in my bedroom with a Squeezebox to pull music from my server. Now I just need to make a small set of speakers. |
#2 |
Guts:
#3 |
Amp Section
#4 |
Power Supply:
#5 |
Rear Panel:
#6 |
very nice job! if you dont mind me asking where can you get perforated aluminium. i have been looking for some!
(please dont say onlinemetals.com the government loves to rip me off big time importing from there!) |
#7 |
I bought the perforated aluminum from McMaster-Carr, which probably isn't any better than ordering from Online Metals.
#8 |
beautiful
#9 |
Is that a Noble Pot?
How did you make the connection to it? solder right to the leads or use some fancy clips?
Two little mice fell in a bucket of cream. The first mouse quickly gave up and drowned. The second mouse, wouldn't quit. He struggled so hard that eventually he churned that cream into butter and crawled out. |
#10 |
Yes, it is a noble pot and I soldered directly to the leads.
| GC completed | schumpe | Chip Amps | 5 | 12th June 2007 07:45 AM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| HELP! Completed sub is bad! | pne123 | Subwoofers | 20 | 17th February 2004 10:34 AM |
| My amp is completed ! | SDF | Solid State | 18 | 10th April 2003 12:29 PM |
| Page generated in 0.23529 seconds (39.66% PHP - 60.34% MySQL) with 11 queries |
