Old 9th April 2006, 06:46 PM   #1
Digidoo is offline Digidoo  Netherlands
Default removed volume pots GainClone
A few months ago I finished my first Audio DIY project; a GainClone. It's a quite simple design, two monoblocks and one powersupply. At first I wanted to use a couple of potmeters for the volume, but I used quite low quality ones.
Now I've got a nice DIY pre-amp and I removed the volume pots from my GainClone. The result is an enormous ground problem. Below you can find some pic's of the amp as it is now. Please remember that this is my first project and it isn't very pretty, although it did sound pretty.
The Powersupply, which works fine:
Left:
Right:
How it is in practise:
Thanks for the trouble everyone!
“Of course the music is a great difficulty. You see, if one plays good music, people don't listen, and if one plays bad music people don't talk.”
Old 9th April 2006, 07:29 PM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
I would make sure the RCA plugs are isolated from the case for a start, can't see them clearly on the pictures. Also I would put a -10 -56k resistor between the ground and hot points on the input RCA.
Edit again..
Hah I see Baz also saw that... post
Old 9th April 2006, 07:30 PM   #3
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Ground loops usually uccur due to incorrect wiring.
The output ground must be connected directly to PSU ground.The same for trafo's mid point.
ICs must also go throgh separate ground wires to the same common gound.
It is also important to add ceramic caps close to ICs(100nF or so).
A ~10K resistor across input/Ground helps , when inputs are left floating.
LM3886 must be totally quet if everything is made correctly.
I use gainclone without volume pots too.
Old 9th April 2006, 08:22 PM   #4
neutron7's Avatar
is there any hum when theres nothing connected?
are both amps are sharing the same supply? if so they are not really monoblocks. the ground could be forming a loop from the interconnects sheilds, your preamp and the shared power ground. you could try lifting the ground on one of the preamp outputs.
Old 9th April 2006, 08:42 PM   #5
isn't 1000uF a bit on the low side for reservoir caps?
All this radio needs is a fuse
Alps pots for sale (removed from Pioneer amp) maurycy Swap Meet 2 12th March 2008 03:58 PM
How to ID volume & fader pots? jol50 Car Audio 54 18th January 2008 05:26 AM
volume pots for tube amp Miller-8 Parts 5 16th February 2007 04:29 PM
Volume pots: Why are low values better? Christer Parts 11 9th January 2006 10:41 PM
Best Volume Pots? A3rd.Zero Parts 18 2nd May 2004 04:00 PM
Page generated in 0.13097 seconds (57.87% PHP - 42.13% MySQL) with 10 queries
