Old 8th April 2006, 08:30 AM   #1
Default LM4780 Datasheet Confusion
Hi everyone, I am trying to design an inverting 4780 amp. So i took a look at the datasheet,
http://www.national.com/ds.cgi/LM/LM4780.pdf
and there is a little section about inverting configuration in page 19 and 20. In page 19 it refers to equation 8 to calculate the lower -3dB point if a coupling capacitor is used. However, it seems to me that the equation is not right for the schematic in page 20, since the input resistance is suppose to be RIN//Ri, not RIN alone. Thus the shematic in page 20 should only give me -3dB frequency of about 162.541 Hz, while equation 8 gives a -3dB point of about 3.386 Hz. Can anyone confirm with me whether ppl who wrote the data sheet didn't know what they were doing or I wasted money on my education? Thanks for any help.
Midway
Old 8th April 2006, 01:37 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
You are quite right. 1 uF is a bit little together with 1 kohms. The input impedance is 47//1 = 979 ohms
1 uF and 979 ohms = 162 Hz
I think they meant to have 10 kohms instead!
/Per-Anders (my first name) or P-A as my friends call me
Old 8th April 2006, 07:19 PM   #3
If they had Ri = 10K ohm instead, then the overall gain will be 2 instead of 20, will the 4780 be stable in this case? I have been wondering about this for quite a while too, does the minimum gain of 10 rule apply to the inverting configuration? or just the non-invering configuration? thanks.
Old 8th April 2006, 08:45 PM   #4
peranders's Avatar
The feedback resistor must be 220 kohms or something.
Kit Confusion! deadparrot Chip Amps 6 28th May 2009 08:52 PM
mox confusion cowanrg Solid State 10 9th August 2005 11:11 AM
More(l) confusion mr_push_pull Multi-Way 2 29th May 2005 04:54 PM
I2S confusion MWP Digital Source 2 9th November 2002 10:36 AM
Page generated in 0.11322 seconds (55.46% PHP - 44.54% MySQL) with 10 queries
