Old 8th April 2006, 02:42 AM   #1
Default Single sided GC
I'm planning to build "Tube Gainclone for DIY Buffs", but after losing a lot of time with P2P wiring of an other GC (Never finished, I'm starting over), I decided to build a PCB.
I have not marked the resistors and caps, and there are some that are going to be mounted on-chip, so they aren't there. But I'm not going to silkscreen the PCB and what I'm not sure of is mainly ground, in and out position, and if there are some components poorly positioned.
Antoine
http://dmsaudio.ca/
Old 8th April 2006, 04:30 AM   #2
dfdye is offline dfdye  United States
dfdye's Avatar
It looks like you have the wrong package for a LM3875. I got tipped off when I saw the mute pin (which isn't on the LM3875), but I started looking at the other pins and it looks like you have something goofy going on there. I checked to make sure you weren't using the LM3886, but that didn't make much sense either. Double check your pinouts on your chip for starters. Also, I would put the bypass caps as close to the power pins as you can. That should at least get you started.
David
Old 8th April 2006, 12:39 PM   #3
Well, I'm using LM3886 with the tube scheme for 3875.
The Mute pin seems to have no place to go, but that's because I'm not sure if I'll use it or not. (If I do, the circuit will be on the PSU)
BTW, the PSU is going to be regulated, so, for the caps, I could use only 1000µF, or an other option instead of my original 10000µF plan.
Antoine
http://dmsaudio.ca/
Old 8th April 2006, 01:06 PM   #4
An other attempt, cleaned things a bit.
The hole going nowhere next to the output pin is for the part with 10k 100r 10k part that's going to be mounted off-board:
http://www.customanalogue.com/diytubegainclone/ps.htm
Also, for the pre and regulator, should they be on the same board?
Antoine
http://dmsaudio.ca/
Old 8th April 2006, 03:52 PM   #5
Oops! Here's the file.
Antoine
http://dmsaudio.ca/
Old 8th April 2006, 04:13 PM   #6
phn is offline phn  Sweden
phn's Avatar
Antoine, have you tried Mick Feuerbacher's web site? You have the address already, but HERE it is.
Old 8th April 2006, 09:30 PM   #7
Yes, but I'm not as good in µsoldering as Mick. The Orange Drop I intended to use for the GC schematic I wanted to build first was kinda hard to solder...
I'll get the components first and see if it's easy to do something with them.
So, the PCB is a maybe??, but I think I'm going to use one anyways.
Antoine
http://dmsaudio.ca/
Old 8th April 2006, 11:38 PM   #8
Greg Erskine's Avatar
hi DragonMaster,
I think you need to look closely at the schematic and the LM3886 data sheet. There seems to be a few things wrong. For example, V+ should go to 2 pins and the mute resistor goes to V- not earth. It's a little hard to comment further without the proper schematic.
regards
Greg Erskine
Old 8th April 2006, 11:53 PM   #9
Looked at a couple of designs and they never use both V+ pins...
It's not a mute resistor, but a resistor from Vin+ to GND. Mute is the pin next to it. I'll try to work on it a bit to make it easier to read...
Antoine
http://dmsaudio.ca/
Old 9th April 2006, 12:32 AM   #10
We must be looking at different designs. The ones I look at always have pin1 and pin 5 connected to V+.
I've got my glasses on now - I can see its not the mute resistor now.
regards
Greg Erskine
Single sided PCB for Zen v4 kirc Pass Labs 59 3rd May 2012 11:29 AM
X-over for single sided tweeter. Jonathan Bright Planars & Exotics 4 2nd June 2008 07:44 PM
Single Sided PCB for Zen V4 GeorgeBoles Pass Labs 0 29th August 2004 12:55 AM
Single sided PCb for lm4780 rs1026 Chip Amps 11 22nd August 2004 09:16 PM
Single sided gainclone pcb mateo88 Chip Amps 85 8th July 2004 02:51 PM
Page generated in 0.15741 seconds (63.01% PHP - 36.99% MySQL) with 11 queries
