Old 7th April 2006, 11:05 PM   #1
Danko is offline Danko  Hungary
Default TDA7294 sub-amplifier
Hello!
I would like to build an amplifier to my subwoofer, with TDA7294. Can I make a low-pass filter with the TDA7294, if I connect paralell with R3 a capacitor?
I have to calculate that capacitor with the C=1/(2*pi*f*R3) equation, am I?
I attached the schematic, where you can see R3.
Thanks in advance!
Best regards, Danko
Old 8th April 2006, 01:48 AM   #2
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
For a sub-woofer , you need a 12 db/octave filter at least(i would prefer using 18-24db).
If you connect a cap in paralell to R3 , you will not get more than 6db/octave.
Also , the phase of subwoofer and main speakers must be matched , or there will be frequency response nonlinearities at crossover point.
You can find some examples of active filters here :
http://sound.westhost.com/projects-3.htm
Also , there are lots of programs , like LSPCad , which allow you to calculate any order active filters easily.
Lukas.
Old 8th April 2006, 06:53 AM   #3
Oh, I just wanted to avoid +1 circuit :-)
I have biuld a few of this:
http://sziget.mine.nu/~danko/aramkor...filter-sch.png
I'm going to build another one.
Thanks, Bazukaz, for explaining why required an active filter!
Best regards, Danko
Old 20th June 2006, 10:15 PM   #4
Just curious to see if anyone has used this one for a full range "CHIP AMP" and if so how it performed.
Old 21st June 2006, 09:14 AM   #5
ilimzn is offline ilimzn  Croatia
Yes - there is an old thread about it. To my ears it performs surprisingly well, but then I did use a separate well filtered and regulated supply for the input part of the chip. This requires some precautions to be taken in order to produce correct power supply sequencing (what voltages come at which time at power up), which mostly can be satisfied with two diodes. Chosing proper (higher) voltages for the input power supply also gets you rid of the bootstrap capacitor.
With good attention to wiring and layout, this amp is dead quiet - no hum, no noise. The suond is detailed but has some of that MOSFET 'slightly withdrawn mids' character - which is heared whenever you listen to a recording that was overly mangled in the studio. It also clips far more gracefully than the bipolar LMxxxx amps, which gives it a much better sound on transients.
Still, keep in mind this is for an amp that has a special power supply arrangement designed to halp all this.
Tda7294 e_fortier Chip Amps 2 27th November 2008 01:33 PM
300watts Amplifier with TDA7294 or LM3886 Sebby Solid State 26 23rd September 2007 08:42 AM
My TDA7294 Amp panson_hk Chip Amps 1 27th June 2007 01:06 PM
Need help on tda7294 amp Fossil Chip Amps 6 20th April 2005 02:53 PM
Tda7294 Angel Puerto Chip Amps 6 21st August 2003 02:08 PM
Page generated in 0.10732 seconds (57.47% PHP - 42.53% MySQL) with 11 queries
