Old 7th April 2006, 04:39 PM   #1
zenon is offline zenon  Canada
Default Mains Disconnect
I can get mercury contactors which break either one main line into the toroid or both main lines. For 110v which should I use?
Also, it is triggered by 24vac, what would be the best way to trigger this signal (the idea here is to be silent, hence the mercury contactors)
TIA.
Old 7th April 2006, 05:20 PM   #2
paulb is offline paulb  Canada
Is a "mercury contactor" the same as a mercury-wetted relay?
What exactly are you trying to do, and why do you need it to be "silent"?
Old 7th April 2006, 07:37 PM   #3
Stocker is offline Stocker  United States
Sounds like an on-off switch idea to me... needs a switch?
contactor = big relay
silent, vs. CLADCK when you turn on the amp with relays.
Jesus loves you.
Old 7th April 2006, 09:14 PM   #4
dfdye is offline dfdye  United States
dfdye's Avatar
Mercury = bad. Regardless of the electronics argument, the toxicity should scare you off some.
Just my opinion, but if you are willing to chance a broken switch and subsequent mercury vapor exposure, be my guest.
Old 7th April 2006, 10:17 PM   #5
How much aperage can one of these little chipamps really draw? The contactors I have are rated for 30A @ 600vac. The beauty about them is that when they switch on and off they are completely silent, no loud "clack".
Now, I can get one that is a single line contactor (breaks ony one line) or a dual line (switches two lines @ once).
Now, it is my understanding that when you use 1 phase power (north american 110vac) that you wire the neutral always connected and Line One (the powered wire) you switch on and off. If this is the case I'll save some space and use the single contactor, otherwise I'll use the dual.
Old 7th April 2006, 10:22 PM   #6
Regarding the "Signaling" voltage of 24vac, is there some type of solid state relay that won't make any clicking sound that I can use to trigger the contactor?
Old 7th April 2006, 10:22 PM   #7
dfdye's Avatar
I use DPST (breaks both lines) switches, but I have heard of many others using SPST (breaks one line) switches.
As for the power rating, I have a 3A slowblow fuse for my stereo LM3886 amp and that hasn't given me any problems. I am sure that your 30A switch will be more than sufficient for a stereo amp.
Old 7th April 2006, 11:09 PM   #8
Is this contactor going on the 120VAC side of the transformer? Are you sure you're qualified to do this?
Old 7th April 2006, 11:17 PM   #9
yes, it will go:
120 VAC -> Fuse (?3-4? Amp) -> DPST Contactor -> Transformer
Isn't this how most people are wiring their power supplies?? or they switch power after the transformer??
Old 8th April 2006, 12:45 AM   #10
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
I got some of these
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
so I could use a knob that matches the other controls on my equipment...Lots of ampacity also!!
Not quiet probably and they might "feel" cheap- we'll see
Can I solder to this 0.25" terminal or do I need to use a female quick disconnect? 454Casull Parts 5 24th February 2009 05:37 PM
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 02:31 PM
Disconnect CD digital output? float Digital Source 4 6th August 2005 12:35 PM
Mains Isolation 5th element Parts 26 19th June 2004 04:52 PM
DIY Mains Cable Blue_Max Everything Else 0 15th May 2004 12:24 AM
Page generated in 0.73913 seconds (12.53% PHP - 87.47% MySQL) with 10 queries
