Old 6th April 2006, 07:47 PM   #1
ahanlon is offline ahanlon  Canada
Default Leaving a gainclone powered on?
Hello all,
A big thank you to everyone on this site, I've recently finished my second gainclone and it sounds pristine.
I have a couple of questions about the power consumption of a standard lm3875 audiosector style gainclone: If there is no audio being input to the amp, how much power (approximately)would the amp consume. And following the above, is it safe / a good idea to leave the amp powered on for extended periods of time without input?
thanks again to everyone,
drew
Old 6th April 2006, 08:36 PM   #2
Bricolo is offline Bricolo  France
Bricolo's Avatar
That's no problem, a gianclone only consumes a few watts
That's that I did with mine
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 6th April 2006, 10:32 PM   #3
pinkmouse's Avatar
You could do it, but why bother? Amongst many things I've noticed about GCs, needing warm up time is not one of them.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 7th April 2006, 12:00 AM   #4
XELB is offline XELB  Portugal
I think that everyone knows that the LM3886 or LM3875 sounds much better when hot
If you want power you must add control
Old 7th April 2006, 12:05 AM   #5
pinkmouse's Avatar
I've quite frequently had one channel of a GC running while I had the other pulled out and on the bench, and when I reinstalled that one back in the amp and ran it up, there was no difference between it and the one that had been running.
Al
Old 7th April 2006, 07:26 PM   #6
Default Thanks
Thanks for all of the info. I was mainly just wanting to use my ipod as an alarm clock, and to do so I would have to leave the amp on over night. I guess it would be no problem.
Thanks again.
Old 8th April 2006, 04:55 PM   #7
Thanks again.
The PSU(including transformer) is burning watts when connected tho.
You could put a cheap plug-in timer that cuts the current when you're sure that the alarm will not start.
There are also some circuits that detect what's on the input and start the amp when there's a signal
Antoine
http://dmsaudio.ca/
Old 10th April 2006, 02:25 PM   #8
komen is offline komen  Finland
In commercial electronic equipment there is quite tight safety requirements concerning fire hazards. Either fire resistant enclosure or some other protection is usually required. Risk of fire should be taken very seriously also in DIY audio equipment.
There's no need to worry if you have metal enclosure or plastic enclosure made of certified fire resistant plastic and all internal materials are non-flammable.
If you have wood enclosure or anything similar and you want to leave chip amp powered on unsupervised you should be very very sure that there is absolutely no possibility of fire in case of any component failure.
I think LM3875 power consumption is typically around 2 watts per channel without signal.
Old 10th April 2006, 03:19 PM   #9
Electrons are yellow and more is better!
peranders's Avatar
I think it's a good rule to shut the gear off when you not are using it.
/Per-Anders (my first name) or P-A as my friends call me
Leaving tube preamp always powered on. stoolpigeon Tubes / Valves 31 20th April 2007 08:59 PM
Driver Options for Gainclone powered Sub raromachine Subwoofers 26 16th February 2007 07:47 AM
Leaving X-former powered up Wynand Power Supplies 4 16th May 2006 02:07 AM
Battery powered gainclone grounding? abkingsbury Chip Amps 0 10th August 2004 05:51 AM
I had serious doubts (Gainclone powered LT Sub) and... PaulHilgeman Multi-Way 2 6th June 2003 04:22 AM
Page generated in 0.10205 seconds (75.71% PHP - 24.29% MySQL) with 10 queries
