Old 3rd April 2006, 07:44 AM   #1
alizawi is offline alizawi  Palestine
Default AC connector
would this connector be suitable for an LM3875 project?
http://www.partsexpress.com/pe/showd...number=090-443
or will the 10A fuse be a problem and in that case i should stick with this one:
http://www.partsexpress.com/pe/showd...number=090-442
thanks.
Old 3rd April 2006, 08:04 AM   #2
lndm is offline lndm  Australia
10A at 110VAC? That would be 1.1kW RMS
I like the idea for fuse access, maybe you could put a lower rated fuse in there.
Old 3rd April 2006, 08:12 AM   #3
phn is offline phn  Sweden
phn's Avatar
If you think the fuse is a problem, then it probably is. Otherwise, no.
I like the fused version. I believe the fuse on the transformer secondary is more important, but like one on the primary as well. (I'm a safety first guy.) And I think Indm is right. I believe mine are 2.5A.
Old 3rd April 2006, 08:25 AM   #4
A bunch of links referenced on this forum recommend using 5-6 A fuses on the primary end. I guess I can take out the 10 A one and replace it as suggested
Old 3rd April 2006, 03:03 PM   #5
BrianDonegan's Avatar
I think there is a little confusion. The fuse holder can handle *up to* 10A. I don't think the connector actually comes with any fuses.
Use the fused connector and the appropriate size fuse for your project.
Twisted Pear Audio
Old 3rd April 2006, 05:35 PM   #6
RDL2004 is offline RDL2004  United States
Note last part of description: "Fuses sold separately". The receptical itself is rated for anything up to 10 amps.
These will work fine, however be aware that with the snap-in kind, your panel thickness and how accurately you cut the hole is very important. I prefer the screw mount type myself, the hole can be pretty sloppy and panel thickness is irrelevant.
- Rick
Old 3rd April 2006, 06:41 PM   #7
lgreen is offline lgreen  United States
lgreen's Avatar
Rick is right, unless you are very good at cutting the square hole there is a good chance that the snap-in type will not be in there very securely.
In which case you will want to use the same type that is a screw-mount. Like Q201-ND (Fig. 1) at digikey.
My DIY audio projects- PartTimeProjects.com.
Old 3rd April 2006, 07:01 PM   #8
Good lookin out, I just read the info real fast, didn't notice the fuse wasn't include.....about the hole, i might get my holes done professionally, but if I do them myself i guess i'll stick with the other connector........ by the way, which switches are best...SPST, DPDT or any other kind?
Old 3rd April 2006, 11:02 PM   #9
Apex Jr is offline Apex Jr  United States
Default Another Option
I have these in stock at $1.49ea
http://www.apexjr.com/images/IEC_POWER_RECPT.jpg
Receptacle - Fuses - and Switch together
Steve @ Apex Jr
www.apexjr.com
Old 4th April 2006, 12:50 AM   #10
what do you guys think about the apex ones...looks like the best solution to me
Name this Connector thermionic Parts 7 16th July 2009 03:31 PM
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 07:21 PM
ID PCB connector for me please? markiemrboo Chip Amps 3 11th November 2006 12:19 PM
F-connector vs. BNC pooge Digital Source 6 2nd August 2006 08:53 PM
ATX connector MaXiZ Everything Else 15 3rd January 2006 08:02 AM
Page generated in 0.11480 seconds (72.19% PHP - 27.81% MySQL) with 10 queries
