Old 6th April 2006, 06:13 AM   #11
And schematic ( for completeness... ).
Old 6th April 2006, 02:12 PM   #12
poobah is offline poobah  United States
poobah's Avatar
Stephen,
I was thinking more in terms of Kurt Vonnegut's usage of the asterisk... think it was in "Breakfast of Champions".
Old 6th April 2006, 02:33 PM   #13
AndrewT is online now AndrewT  Scotland
Hi Upupa,
re posts 9 & 10: are the upper & lower star grounds connected by the bolt (set screw) through the rectifier sink?
That is probably the most (18) I have seen, ever!
regards Andrew T.
Old 6th April 2006, 02:38 PM   #14
Hi Upuppa,
is the 134/634 buffer based on the Jung topology?
Which chip is SMD?
regards Andrew T.
Old 6th April 2006, 04:22 PM   #15
Hi Andrew, " main point " of grounding is below rectifier, both sides connected together... And WJ : yes, 634 have " diamond " topology. PCB is universal, for soic and dil opamps...
Old 6th April 2006, 11:03 PM   #16
dfdye is offline dfdye  United States
dfdye's Avatar
Dumb question, but why not use a ground plane instead of a star ground?
Old 6th April 2006, 11:24 PM   #17
poobah's Avatar
dfdye,
I use grounds planes all the time and then star them together at single point. Ground planes are not always good things. They can be handy shields, and they can control impedance for high speed stuff, but they can also be awesome couplers (un-wanted) as well.
So in the spirit of jneutronesque analosity, they should be applied thoughtfully... ground is a myth.
Old 6th April 2006, 11:27 PM   #18
pinkmouse's Avatar
Personally, I like separate ground tracks to a star, then flood everything else with the ground plane. I'm sure there may well be reasons why you shouldn't do it that way, but it's always worked for me.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 6th April 2006, 11:38 PM   #19
poobah's Avatar
That's an EXCELLENT way of doing it pinkmouse...
Flooding your boards with copper helps to keep them from warping in wave or reflow operations too. It's going to be worse with this new RoHS ****!
Old 6th April 2006, 11:43 PM   #20
pinkmouse's Avatar
Pavel taught me to do something right then! Now we just have to work on the rest...
Al
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
What resistor should I use? Rob11966 Tubes / Valves 1 2nd March 2009 09:52 AM
Why this resistor? Shel-e-bean Everything Else 28 4th August 2006 04:57 AM
Help with Resistor Please saabie22 Parts 5 2nd February 2005 09:39 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Page generated in 0.08358 seconds (85.78% PHP - 14.22% MySQL) with 11 queries
