Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 2nd April 2006, 05:47 PM   #1
nina is offline nina
Default questions on Capacitor rating?
Just wonder if there are any recommendation on how to select voltage rating for capcitor, esp. filter cap? How many percent of extra volatge rating required?
Is that safe to use 56Vdc (from 40-0-40 tranformer) with a cap 63V?
Thanks,
Old 2nd April 2006, 05:49 PM   #2
anatech is offline anatech
anatech's Avatar
Hi nina,
Yes, you are perfectly safe.
-Chris
Old 2nd April 2006, 06:08 PM   #3
pinkmouse's Avatar
Well, the caps may be safe, but the chip amp would likely blow up, 56 V rails are way over spec for all the ones I can think of.
Al
The miracle is not to fly in the air, or to walk on the water; but to walk on the earth.
Chinese Proverb
Old 2nd April 2006, 06:16 PM   #4
AndrewT is offline AndrewT
40Vac will take the 63Vdc cap right to the limit if the regulation of the transformer is about 5%.
If the transformer regulation is more than 5% then you should use 75Vdc or 80Vdc caps.
But Pink is right. You probably need a 25Vac or 30Vac transformer.
regards Andrew T.
Old 2nd April 2006, 06:24 PM   #5
anatech's Avatar
I guess the question now is, what chip amp? What is the N.L. DC voltage? Some STK chips will run this high.
Andrew is correct in that an unloaded transformer will output a much higher voltage than it's rated at. Your AC mains could very well take this over the cap rating.
It is okay to use a 63V cap when the measured DC is around 56V. I have seen worse in mass market units.
-Chris
Old 2nd April 2006, 06:29 PM   #6
poobah is offline poobah
poobah's Avatar
Did Nina say chip amp? Who said chip amp?
Caps these days are generally given 2 ratings: "WORKING VOLTAGE" & SURGE.
Caps perform at their peak when run as close to, but NOT over their WVDC (Working Volts DC) rating.
So... 40 times 1.414 times 110% = 63 Volts... PERFECT!!!!!!!!!!
Pull up to the second window...
Old 2nd April 2006, 07:11 PM   #7
pinkmouse's Avatar
We are in the chip amp forum!
Al
Chinese Proverb
Old 2nd April 2006, 07:15 PM   #8
poobah's Avatar
uh... uh... uh...
Old 2nd April 2006, 07:15 PM   #9
anatech's Avatar
Yup,
Poobah, some times it's all about location, location, location.
-Chris
Old 2nd April 2006, 07:17 PM   #10
poobah's Avatar
Jeeze guys... I'm working with 2 brains cells here... one wants a drink and the other has a hangover.......
Thread Tools
PS Capacitor Voltage Rating dsavitsk Tubes / Valves 3 16th January 2006 03:37 AM
Oil Capacitor DC vs. AC Voltage Rating valveitude Tubes / Valves 2 11th June 2005 12:45 AM
Capacitor Voltage Rating diyman Solid State 2 21st December 2004 03:49 PM
Capacitor Voltage Rating Super_BQ Parts 14 22nd September 2001 04:50 AM
Page generated in 0.25905704 seconds (81.06% PHP - 18.94% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
