Old 2nd April 2006, 04:50 PM   #1
Default Gainclone: 2 newbie questions...
Hello
What do u recommend as highest Voltage for foolproof and SAVE operation with 4Ohm Loads?
18V Transformer seems to be OK, what about 22V?
And what happens, when a 3886 dies? Will it kill my speaker?
Possibly DC to the speakers?
Old 2nd April 2006, 04:53 PM   #2
nina is offline nina  United Kingdom
I guess you means AC.
Though 22-0-22Vac should be fine provided you get big enough heatsink, the 18V-0-18Vac provide better margin of safty.
Old 2nd April 2006, 09:33 PM   #3
cpemma is offline cpemma  United Kingdom
It also depends on whether you use the 3886T or 3886TF package, see the Overture Design spreadsheet for the NS recommended max DC rail limits, which means the quality of your thermal interface is also important when you're living near the edge.
Old 2nd April 2006, 10:04 PM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
Just about any amp can kill your speaker if it blows.
Old 2nd April 2006, 10:40 PM   #5
@nina:
I mean AC.
@cpemma: I cant find any difference between T and TF in the sheet
Old 2nd April 2006, 10:55 PM   #6
RDV is offline RDV  United States
Originally posted by Bassterror
@nina:
I mean AC.
The TF has an insulated case. The T carries the negative rail voltage on the case.
RDV
Old 2nd April 2006, 10:58 PM   #7
For a 4 ohm load you will need a larger than normal heatsink also. I'm speaking from experience. Chipamps love 8 ohm loads and hate 4 ohm loads.
RDV
Old 3rd April 2006, 12:18 AM   #8
Yes, I know. But does that affect the heat flux?
Right now I've got 8 ohm speakers at my computer. But I want them to be capable of driving 4 Ohm loads. I want to be flexible.
Assuming I torture them with 4Ohm.
- Will this affect the sound seriously?
- What will happen when they get too hot?
Can I hear them suffer before it's to late?
Old 3rd April 2006, 01:14 AM   #9
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Bassterror asked:
Sort of, indirectly. If you use the "T" version, you must isolate the heatsink from other circuit elements, OR use an insulating washer to isolate the chip from the sink. Your choice (there are several options) of insulating washer will directly affect the heat flux.
If you use the "TF" version, no added washer is needed. You should use heat transfer paste with either version.
Old 3rd April 2006, 02:19 AM   #10
Assuming I torture them with 4Ohm. Yes, but with enough heatsinking and not too high supply voltage it will survive.
- Will this affect the sound seriously? No.
- What will happen when they get too hot? Thermal Shutdown until temp goes down below shutdown threshhold.
- Can I hear them suffer before it's to late? No.
australian gainclone newbie sparehead1 Chip Amps 17 27th August 2009 02:50 PM
Humm in a gainclone by a newbie spacemen12 Chip Amps 7 27th March 2006 03:40 AM
Gainclone Newbie Help LM3886 pitamista Chip Amps 8 16th March 2006 04:42 PM
gainclone real newbie doggy Chip Amps 7 28th September 2004 04:57 PM
Yet Another Newbie Gainclone Kofi Annan Chip Amps 27 10th March 2004 02:27 PM
Page generated in 0.12173 seconds (76.08% PHP - 23.92% MySQL) with 10 queries
