| Chip Amps Amplifiers based on integrated circuits |
After building a set of LM3886 amps based on the Linkwitz circuit (which I really like!), I figured I would try an amp using the LM4780 based on the same circuit layout. Since I haven't used this chip before, I figured I would ask:
1) If anyone has used the Linkwitz circuit ( http://www.linkwitzlab.com/images/graphics/3886amp.gif ) using the LM4780 as two LM3886's. I know other amps (Brian and Peter's come to the front of my mind) use this chip in a similar manner, but I was specifically interested to see if anyone has used the Linkwitz topology. It should be fine, but there is no since in re-inventing the wheel if there is someone who has already found out any issues. (Searching the forum didn’t show much, but I figured someone has to have done this!!!) And 2) Attached is a proposed PCB that fell together rather nicely, but I figured I would run it past more experienced designers first. Particularly, I am concerned about the V+ section coming from the input pin header to C+ and the input signal traces running along the top right edge of the board. If anyone has any comments either way as to whether my concerns are justified, or if I am in good shape, I would appreciate the feedback. Any suggestions or comments about the rest of the board are welcomed as well! Thanks! David As a side note, I started off trying to make this a single sided PCB. That idea got trashed rather quickly, but I was wondering if anyone has used a single sided LM4780 PCB? |
#2 |
Well, I hope nobody finds anything! I just dropped in a prototype order (with a bunch of other stuff too . . . ) so I guess we will see how it comes out!
David |
#3 |
just letting you know that someone is reading your thread with interest...
-Dwight |
#4 |
do you mean to use additional opamps, or use the LM4780 itself as one of the components in a filter network?
#5 | |
(If I misunderstand your question, please forgive the basics. . . .) I am treating the LM4780 as two LM3886's. If any additional filtering is required, I will indeed use external components. I am currently planning on using these as part of a multichanel amp that will drive actively filtered speakers, so yes, I will be using additional opamps as a filter network, but I am not considering the LM3886's to be part of that filter network. The exception is if I use the two 220uf electrolytics in CGA/B instead of a 10uf film cap. This effectively filters most of the high end response if you are using these amps for woofers. This amp layout is pulled right from linkwitzlab.com, but I guess a copy of the schematic might be helpful. The Ci* cap does add a filtering, but again, that is not really the point of this circuit. If this is not what you were asking, sorry for the tangent. ![]() David |
#6 | |
David |
#7 |
Looks pretty good. I'm having a hard time keeping the output stable in a bridged configuration. Make sure you use small bypass caps very close to the chip and keep leads short and neat. Ballast resistors are required if you plan to bridge channels.
#8 |
Rail lines are too slim, David. Image it in real size and imagine, that there should " flow " 10 A....
#9 | |
#10 | |
David |
| new LM4780 layout, any comments? | BrianGT | Chip Amps | 61 | 30th June 2009 03:18 PM |
| Wanted PCB' for LM4780 INDIA | yusuf | Group Buys | 1 | 12th February 2009 05:07 PM |
| TAS5015 is now NRND, comments/possible replacement wanted | nbdy | Class D | 10 | 20th May 2006 05:47 PM |
| Dayton RS HiFi 12" Sub using Linkwitz Transform EQ--Design Proposal | dfdye | Subwoofers | 23 | 24th January 2006 01:18 PM |
| GC PSU PCB comments wanted :) | wxn | Chip Amps | 11 | 16th December 2004 02:22 PM |
| Page generated in 0.12729 seconds (70.77% PHP - 29.23% MySQL) with 11 queries |
