Old 1st April 2006, 07:41 PM   #1
Default Power supplies and transformers
First of all, I'm sorry for my (possibly) stupid questions.
I've started building BrianGT's 3886-based amp and power supply and everything has been going great, but I've never worked on an electronic project that has involved AC and that's making me a little scared so I'd like a little help before I proceed. I bought a toroidal transformer and I think I've figured out how to hook it up, can you please tell me if I'm correct. The transformer has the following picture (please admire my beautiful ascii art :-)):
Code:
BLU ----- | ----- BLK 0V
GRY ----- | ----- RED 25V/6.6A
2X115V    |
VIO ----- | ----- ORA 0V
BRN ----- | ----- YEL 25V/6.6A
The power supply PCB has 'AC1' and 'AC1-' (the dash signifies the hat on the PCB (I'm assuming that it's a significant mark)) and 'AC2' and 'AC2-'. I am assuming that I connect Black to 'AC1-', Red to 'AC1', Orange to 'AC2-', and Yellow to 'AC2'. Then I connect both Blue and Violet to one of the AC inputs, and both Gray and Brown to the other. Is this correct? Also, on which one of the AC inputs does the fuse go or does it even matter? And what do the dashes on the left side of diagram mean, there's no positive and negative leads in AC right?
BTW, this forum kicks ***, I've been lurking for a few weeks now and learned a lot.
guido.
Old 2nd April 2006, 07:18 AM   #2
lndm is offline lndm  Australia
What you have said sounds good.
Could I suggest you find a mains primer to read? There is a sticky one here. (Not because you sound like you need it or anything )
It is good practice to fuse each side of the xfmr. Your board should have provisions for fuses after the xfmr, you need to ensure there is fusing before the xfmr. Choose the active lead for the fuse (if you have one in the US, sorry I don't know). Neutral is considered to be closer to Earth. Therefore, while AC is bi-polar, it is not as straight forward as that.
Old 3rd April 2006, 02:16 AM   #3
You are right, I do need to learn more about the mains, but I couldn't find anything on this forum and it's been hard to find anything useful on google. I did read a little about mains in wikipedia, and I found some really good info about transformers and AC power at some other sites, but I can't seem to find anything that has pragmatic info for n00b amp builders.
Like, what exactly does the dash on the transformer drawing signify? Is it the neutral lead?
Old 3rd April 2006, 07:05 AM   #4
Maybe they are dots (or meant to be)? If so, they indicate ends of the windings so you can keep them in phase as required.
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
HYPEX Parts F/S! HG Mono Power Supplies, Soft Start, TR501A Transformers! Socrates428 Swap Meet 0 27th April 2008 01:30 AM
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 04:21 AM
Who supplies the cheapest toroidal transformers in uk? homertooties Solid State 3 8th December 2006 11:30 AM
Regulated Power Supplies for Low Power Amps PTL60 Solid State 18 6th February 2002 06:24 AM
Page generated in 0.06954 seconds (75.74% PHP - 24.26% MySQL) with 10 queries
