Old 27th March 2006, 09:10 AM   #1
Onvinyl's Avatar
Default Opamp layout rules
I have a few questions concerning proper (or maybe optimum ) physical layout of an opamp circuit with not-so-easy to tame chips and tiny input signals.
1) What to do with internally-not-connected-pins? Should they be grounded or left floating?
2) If I use a groundplane, is it wise to have the area under the chip grounded, or better leave it out? (I've seen both)
3) The datasheet of opa627 says to use a guard ring around the inverting input. Is that guard referenced to ground?
thanks,
Rüdiger
Old 27th March 2006, 10:15 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
1 Leave them be, safest also in the future if you want to use some other type. Notice that in some case like TPA6120 you should connect them in order to get better cooling but as always, read the datasheet carefully.
2 It's normally not a problem. One square centimeter = 3 pF only. This is valid for to areas of the same shape. In real life you are dealing with a fraction of a pF. In some cases it is important but not in normal audio circuits.
3 This is only important for high impedance signal sources, >> 1MOhms forget it in audio circuits, but no harm to use it either.
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 27th March 2006, 10:20 AM   #3
pinkmouse's Avatar
The main issue with these fast chips is to get power rail decoupling caps as as close to the pins as possible. Surface mount components are good if you can get them.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 27th March 2006, 10:23 AM   #4
peranders's Avatar
Indeed, groundplane and tight placed decoupling is good.
Check C6 and C13. Notice that the pcb has now the groundplane connected on both sides.
http://home5.swipnet.se/~w-50674/hif...r0_TPA6120.jpg
Old 27th March 2006, 10:27 AM   #5
Onvinyl's Avatar
P-A, interesting detail. Do C6, C13 connect directly to the groundplane on the underside or did you establish a star-wired route?
Rüdiger
Old 27th March 2006, 10:27 AM   #6
AndrewT is online now AndrewT  Scotland
the guard ring should be connected to a source of equal voltage.
This is to minimise the leakage current from your input.
You can often find examples of guard rings in the data sheets.
Old 27th March 2006, 10:31 AM   #7
peranders's Avatar
Rüdiger
Now I have "crosses" on both sides. The first batch had this error.
http://home5.swipnet.se/~w-50674/hif...v07pcbcomp.jpg
http://home5.swipnet.se/~w-50674/hif...v07pcbsold.jpg
Old 27th March 2006, 10:32 AM   #8
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
Decoupling question:
In an active crossover, would i have to use two 0.1uf MKP decoupling caps for each opamp?
Old 27th March 2006, 10:35 AM   #9
peranders's Avatar
Yes, it's a good rule, no need to save parts. If you happen to use fast opamps, then it's even more important.
Old 27th March 2006, 10:36 AM   #10
Onvinyl's Avatar
Hi Andrew,
equal to what? Vcc? Vin? (It's DC, I guess)?
If I use an opamp in inverted mode (and thus the signal feeds in the inverted input), is it wise to reference the shield of the signal cable with that voltage (rather then ground)?
Rüdiger
Check my layout pls. for proper grounding (6 channel opamp pre) Groundloops Solid State 9 17th February 2008 08:35 PM
layout rules Stefanoo Solid State 6 5th March 2007 06:01 PM
X 250 Rules...Less is more macka Pass Labs 26 9th July 2005 02:26 AM
Rules for capacitors... Htguy Analogue Source 4 28th May 2005 07:06 PM
83 safety rules Tomatito Tubes / Valves 5 17th May 2003 11:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
