Input cap?
Input cap?
Old 22nd March 2006, 06:09 PM   #1
CJ900RR is offline CJ900RR  Sweden
Default Input cap?
Edit: this questions is for the LM3886
Do you really need a input cap with a resistor to ground? I guess it acts like a low-pass filter, right or wrong?
I didnt use it in my first, exprimental, gc but i have added it to the one i use now, and i think that my first one sounded way better. Specially in middle and high frequensys. And it isnt present in the National datasheet.
And i have also added a 220pF cap (Cc in Nationals datasheet) between leg 9 and 10, as suggested in the datasheet (did that on my first amp to) and it made the amp more friendly to my ears.
But, if i still need a input cap with a resistor to ground, how do i calculate the requierd values for it? And regarding the cap between leg 9 and 10, does a bigger cap (470pF for example) means that it let thrue higher freq. and a smaller cap (100pF maybe?) means that it cuts earlier?
Best regards, Carl-johan...
Old 22nd March 2006, 06:34 PM   #2
Deltat is offline Deltat  United States
Send a message via AIM to Deltat Send a message via MSN to Deltat Send a message via Yahoo to Deltat
Actually that would be a high pass filter. You dont need it if your 100% confident your not going to be getting any DC on your input signal. The equation for the cut off frequency it 1/(2piRC)
So lets say you use a 10uF cap and 100kohm resistor you will have a cutoff frequency (or 3dB down point) of about 1.5Hz. This will block any DC and will not affect your passband range.
Old 22nd March 2006, 06:35 PM   #3
jaudio is offline jaudio
Default Re: Input cap?
No but watch the dc offset
High pass
159155/(Hz * R)
159155/(Hz{cutoff frequency} * R{resistor to ground)= Cap value. What ever cutoff frequecy you want divide that by four
The larger the cap the earlier the cutoff
Old 22nd March 2006, 07:11 PM   #4
Well there you see! Thank you both of you. My input cap now is 1uF and the resistor is 47k. To narrow for me. I will try a 10uF and a 100k tomorrow and see how it sounds.
Many thanks, Carl-Johan...
Old 22nd March 2006, 07:41 PM   #5
Nordic is offline Nordic  South Africa
Nordic's Avatar
Note, that the quality of this cap can make or break your amp.
Old 23rd March 2006, 12:58 PM   #6
A 1uF and 47k should be fine as the cutoff frequency is 3.386Hz which is still infrasonic.
Old 23rd March 2006, 09:17 PM   #7
In fact it wasn't fine. The amp lost it's life with those values
But now whit the new values it's alive and kicking again The hig's and middle is way more seperated and it's a clear sound. Just the way i like it. Before, all the middle, high and sometimes lower frequens allmost floated together.
The only thing to adjust now is the bass, witch hopefully will be more sharp after some power-adjustements.
Old 23rd March 2006, 10:43 PM   #8
What is the value for the resistor and cap, you are now using?
Old 24th March 2006, 05:16 AM   #9
Nordic's Avatar
The bass is in the cap, get a decent $10 input cap and you'll see.
Old 24th March 2006, 12:46 PM   #10
Can you make a suggestion on where to look?
Input cap?Hide this!Advertise here!
Input transformer: floating input = distortion ErikdeBest Tubes / Valves 13 20th January 2009 09:36 AM
Class D input LM311 Inverting input zox2003 Class D 1 1st February 2008 07:48 AM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
convert Quad44 radio input to CD input jives11 Solid State 11 5th March 2005 02:33 PM
Resistor-Input vs. Choke-Input vs. Cap.Multip. Blitz Pass Labs 13 26th September 2003 04:59 AM
