| Chip Amps Amplifiers based on integrated circuits |
As a rule of thumb, most PSU designs use multiple discrete bridges, and multiple windings. However, it appears (I'm going by NUUK's page here) that one can also use a center-tapped transformer with the AC leads going to the bridge, and the center tap to the power star ground.
What is the disadvantage to this method? I'd like to build a Carlos Filipe style unregulated PSU; would this defeat the point? Should I go for multiple smaller transformers, or perhaps just find a way to cut the winding in half? |
#2 |
Hi
I've tried to cut the Center tap winding of a transformer and it works, I had flyout leads and the windings behave perfectly, if correctly identified. It also works fine the other way, with a single bridge and the Center tap of the transformer connected to ground. That works too, and sonically I'm not sure I can hear any difference between the two configurations. There is an explanation somewhere on this forum which says that two windings/bridges allow each half of the supply to get its own return path to ground (I assume without having to include a big fat inductor in the said path). How that makes sense I'm not exactly sure but someone can hopefully drop in and shed some more light on it. |
#3 |
I have had excellent results with a single rectifier bridge and if you have a centre tapped transformer and don't fancy opening it up to separate the windings, try it with one bridge. It's really not that inferior to using two!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
I believe the centre tap is not inferior at all. It gains in reducing the diode volts drop by half (from 2.8V to 1.4V). It's disadvantage is that the rectifier is never allowed a cooling rest period between alternate charging pulses. It also allows current to take shortest route cap to cap and cap to transformer. Theses charging currents inherently have a very high peak value and both methods of wiring need to take this into account to minimise injection of buzz into your clean ground. |
#5 | |
On a purely theoretical basis I can't see a big advantage, but we're talking about playback systems for music, so the proof of the pudding is in the eating. If using separate windings with separate rectifiers sounds better then it does, even if I can't see an obvious reason why it should. Chip amps do seem to be especially sensitive to power supplies, so who knows ... In the end, if you've got a CT transformer then I would go ahead and use it. You can always try dual secondaries on your next project.
| Transformer wiring question, series, parallel and center tapped | swin1 | Power Supplies | 12 | 7th November 2008 07:58 PM |
| two seperate single secondary toroids = combined center tapped transformer?? | gbolly | Chip Amps | 5 | 5th November 2008 03:56 PM |
| Center tapped transformer help | Buzzy | Parts | 2 | 8th August 2008 09:35 AM |
| Two Transfomers => Center Tapped? | Myren | Analogue Source | 6 | 12th April 2004 02:22 AM |
| Giant 1:1 Center tapped transformer fo sale!! | PhaseShift | Swap Meet | 3 | 4th July 2002 07:59 PM |
