| Chip Amps Amplifiers based on integrated circuits |
I have found a reasonably cheap (£37.00) SMPS with +/-15V output (3.9A continuous on both positive and negative legs). While this is quite low voltage for a Gainclone, will this work well with high efficiency speakers (FE207e etc.)?
I have the Audiosector LM3875 dual mono kit. If this supply is sufficient, I intend to use one per channel with a snubberized 10,000uF cap. I have lots of small value <0.1uF russian teflon capacitors I intend using. I plan on making a ladder arrangement of these brilliant caps. Thanks. |
#2 |
Just a thought. Over here you can easily find used laptop SMPSs for €10-15. Some of them have +/-19 or 20V. Why not checking out eBay UK and get two of those for the same price?
Somebody else will have to answer your question. |
#3 |
As I understand it, the problem is this:
An SMPS can only be used if it has equal current available to both the positive and negative legs. The vast majority offer a fraction of the current available to the positive leg to the negative leg. If I'm wrong please let me know and I'll happily save the $$$$ |
#4 | |
The NS Overture design spreadsheet says you'll get 10.7W (1%THD) into 8R from +/-15V, datasheet will give a graph. |
#5 |
I can confirm that the Skynet 8080 SMPS works well with high-efficiency drivers even though the -12 volt rail is only rated at 1 amp (+12v is rated at 6 amp).
I use one module per channel and it sounds beautiful!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
| Computer SMPS and Gainclone | soundNERD | Chip Amps | 25 | 8th March 2013 03:13 AM |
| Best SMPS for Gainclone | sharpi31 | Chip Amps | 38 | 5th June 2010 09:49 PM |
| 13.6/20A new smps | CHACALPOWERS | Power Supplies | 22 | 22nd October 2009 11:59 PM |
| Freebird + Gainclone = "integrated" gainclone? | bikehorn | Chip Amps | 9 | 5th January 2006 03:07 PM |
| SMPS for gainclone | DT | Chip Amps | 23 | 29th March 2005 06:31 AM |
