| Chip Amps Amplifiers based on integrated circuits |
Hello everyone, i am new to this community. I am a crazy fan of audio electronics. Mainly i've used 2050 till now. Actually i wish to know which technique is better for getting more power like:
1. normal bridging . 2. parallel connection of 2 chips 3. fedding inverted input to one IC and non-inverted input to second IC |
#2 | |
About performance, parallel and bridging attend different objectives: paralleling amps increase output current capacity for thirsty speakers, like 4 ohm types; bridging increases output wattage capacity, that is provides more power for 8 ohm speakers. But the actual listened output may depend mostly on speaker efficiency. That is a low efficiency 4-ohm may sound louder than a high efficiency 8-ohm for the same power, when it should be the opposite. |
#3 | |
Electrons are yellow and more is better!
Bridge connection and parallel connection are two different things. To the thread starter: You must first ask yourself how much power you want into which load.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#4 |
Warp Engineer
On Holiday
1 and 3 are the same thing.
- Dan |
#5 | |
Look again: I said 1 and 3 are the same thing, not 1 and 2. Carlos |
#6 |
You did some editing meanwhile I answered as you can see.
#7 |
Maybe 1 and 3 aren't the same thing.
#8 |
Guys,
Have you ever tried this balance circuit? Will it work? I've build it but the output went to positive rail. |
#9 | |
You don't need R3 & R13, if you want you can replaced R3 with 10 ohm 2W resistor parallel with an inductor (single layer winding of gauge 18 enameled wire on the 2W resistor) and remove R13 completely. |
#10 |
With chipamps, for high power you may need to both bridge and parallel, to keep heat per chip in limits. See NS AN1192.
Bridging alone is arguably most commonly done to get maximum watts from a given (and limited) voltage, eg, a car's 12-14V. |
| Amp bridging and performance question | augerpro | Solid State | 10 | 15th June 2008 06:45 PM |
| A Note to the Wise ..... | MJK | Full Range | 3 | 4th September 2006 09:19 PM |
| Is it wise? | lumanauw | Class D | 32 | 18th October 2005 03:09 PM |
| [n00b] Realistic, would it be wise to DIY | moviedrome | Parts | 4 | 14th November 2004 07:27 PM |
