little or no amplification on tda1554 - diyAudio
Old 11th March 2006, 03:49 AM   #1
Default little or no amplification on tda1554
Alright, I have a tda1554 audio chip. I used this schematic for my amp. Right now I don't have any capacitors running on the input but however I should hear some amplification. Here is the schematic I used. Has anyone else had this problem?
Old 11th March 2006, 05:15 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
Default Re: little or no amplification on tda1554
This may be your problem. First: Have you checked the datasheet where you can read how a basic application looks like? A good advice is not to start to change a design without knowing how it works. Since you have a single supply it's most likely that you must have AC coupled inputs and outputs.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 11th March 2006, 08:22 AM   #3
MikeB is offline MikeB  Germany
MikeB's Avatar
Okay, you can't run an amp with single voltage supply without inputcaps, this can't work as the amp will permanently clip at negative, the input is biased to ~Vcc/2 internally. Which schematic did you use, the left or the right ?
Mike
Old 11th March 2006, 02:29 PM   #4
sagarverma's Avatar
using no caps at input is bad idea,more so for a single supply amp.
1554q was my first amp,i tested different values of i/p caps and at last settled for 10uf.
i used 10pf i/p cap also and the result::no o/p for the given i/p.i wonder how u r hearing anything at all.
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Old 11th March 2006, 02:57 PM   #5
i used the right one with the two channels. Replying to the second post, the capacitors just remove the "noise" from the sound input. I should still receive some amplification. Replying to third post, what do you mean by the power supply. I'm a little confused. Right now I'm using a computer psu just taking the 12 volt line and ground.
Old 11th March 2006, 03:21 PM   #6
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Send a message via Skype™ to Bazukaz
It is a simple car audio amp.Probably average in quality , since it is a B class amp.
Have you connected mute pin 14 to Vcc ?
Old 11th March 2006, 03:50 PM   #7
MikeB's Avatar
... the capacitors just remove the "noise" from the sound input. I should still receive some amplification. Replying to third post, what do you mean by the power supply. I'm a little confused. Right now I'm using a computer psu just taking the 12 volt line and ground.
No, that's not what an input cap is for, it's job is to block DC, in this case a quite large amount. By skipping them you force the input down to 0 volt, giving an inputvoltage of ~6v. No wonder the amp does not play... PSU = PowerSupplyUnit. You have a single supply, 0v and 12v. For the amp to be able to create AC at the ouput, it has to be biased to the middle of the supplyvoltage, 6v. You must use the inputcaps, they are not optional.
Mike
Old 11th March 2006, 10:43 PM   #8
alright i placed 10uf capacitors in the input but it didn't do anything...still the same.
Old 11th March 2006, 11:07 PM   #9
MikeB's Avatar
Okay, looks like time to measure... First double check if all connections are exactly as in the plan. Have you connected inputsignal to IN and SIGNAL GROUND ? Then measure if your computer power supply is correctly giving 12v. Most computer power supplies have a minimum load. If it is a ATX supply, you need a special signal to power up the whole thing.
If the 12v are ok, measure the outputs to the speakers, pin 6 to 8 should measure ~0v, but these pins to gnd should measure ~6v.
Mike
Old 14th March 2006, 11:29 AM   #10
sagarverma's Avatar
check polarity of the caps.
-ive side to the i/p(bec its most likely that for 10uf,u would[will] be using polarised caps)
check i/p audio gnd connections to the gnd(suitably on the board)
if all this still doesnt work,double check for dry solder joints.
Mike,
tda1554q is not average sounding,its more than the value for money,with a good power supply it plays very well.
tda1554 amp attempt... mikee12345 Chip Amps 20 27th January 2010 05:27 PM
Where can i get a TDA1554 Ridin '24'z Vendor's Bazaar 1 20th February 2007 04:43 PM
amplification? xstephanx Full Range 29 4th June 2006 05:58 PM
Amplification Howard Subwoofers 5 25th December 2004 07:03 AM
my 1st diy tinny TDA1554 amp! help me.. deepanger Solid State 6 22nd November 2002 01:24 PM
Copyright ©1999-2017 diyAudio
