| Chip Amps Amplifiers based on integrated circuits |
I am in the process of spec'ing out some parts for a p2p gainclone (I am new at building them- but not entirely new to electronics) and was wondering if a pair of 2200uf 50v's would be to high for the rails? BTW, I am using LM3875 chips. I am planning on getting about 35v from the bridge...
Thanks, Wayne Boyd
"I am always doing that which I cannot do, in order that I may learn how to do it" |
#2 |
Not necceraly too high, although many people like to keep the high capacitance levels in the PSU. If you do use them, you will want to solder 0.1uf foil/polyester caps directly over the leads of each cap.
#3 |
Not too high , really.If it is for two channels , it is probably too low.
A 4700uF for a channel would be just right, and not expensive. Regards, Lukas. |
#4 |
Sorry, if he meant for use in the PSU, then yes I think it is too little...
#5 |
If it is specifically a gainclone and not a (different) chipamp, 2200uf is what the 50w Gaincard uses...
Paulo |
#6 |
4700uf/channel is the way to go.
#7 |
you can't just pick a number out of the air -- the size of the capacitance will determine how much the power supply voltage droops under load -- here's a hint -- the chip will take 7 amps max before protection sets in -- with a 60 Hz power supply the diode is "ON" for about 7.5 milliseconds --
the voltage droop (peak to peak ripple) is (approximately) given by the following equation: E = I * t / C with 10,000 uF on each supply rail the droop will be a little more than 5 volts at the point at which protection kicks in. i've used 10,000 to 39,000 and 10,000 seems to be the best choice between economy, size and performance -- the THD tests I ran were all based upon a supply with 10,000uF/63 V Nicchicons. If you had to run an LM4702 for an industrial or laboratory application I would choose 22,000uF. |
#8 |
jackinnj,
I am curious to know which Nichicons you used? I just bought the 10,000uf Super Through Nichicons and have yet to get a lengthy chance to listen to them. Its good to hear that you view this as an improvement though. Dominick
A real amateur enthusiast! |
#9 |
jackinnj,
Thanks for clrifying that for me. I was unsure exactly what the effects would be going too high or too low. everyone, I have built one of the kits and that worked well...but I thought that I would try my hand at a nice p2p version with more "high-end" components. Saving the money for the components rather than spending it on a kit of some sort. I have read many threads on the subject, here and on other forums and have stttled on a design, components and a nice chasis. I would also appreciate everyones suggestions for components. thanks, Wayne
#10 | |
| WTB: 40V+ high-capacitance capacitors | alexcd | Vendor's Bazaar | 0 | 30th May 2007 09:42 PM |
| Very high capacitance before or after regulators ? | Bernhard | Power Supplies | 35 | 23rd January 2007 09:19 AM |
| Zobel for high capacitance cable | kiang | Multi-Way | 0 | 11th July 2005 09:52 AM |
| ZEN vs. high capacitance diy speaker cable? | Vix | Pass Labs | 8 | 4th March 2004 11:31 PM |
| High capacitance | KingsLaw | Multi-Way | 1 | 14th December 2001 05:28 AM |
| Page generated in 0.13544 seconds (73.38% PHP - 26.62% MySQL) with 10 queries |
