Old 9th March 2006, 07:39 PM   #1
Nickzz is offline Nickzz  Sweden
Default lm4780 Dual mono kit from audiosector?
How many volts can i put in to the lm4780?
I found a transformer with 400VA and 42volts does it works?
If you built this kit your self!
please put up some pictures!
Old 9th March 2006, 08:04 PM   #2
Greg Erskine's Avatar
Hi Nickzz,
It is really worthwhile having a look at the LM4780 datasheet, one can be found here: http://www.datasheet4u.com/html/L/M/...uctor.pdf.html
It says maximum voltage is 84V i.e. 42-0-42 VDC.
If your transformer is 42-0-42 VAC then after rectification through a bridge the DC voltage ends up approx. 42 x 1.4 = 59 ouch.
If you need to use this transformer then you can't use a bridge rectifier.
regards
Greg Erskine
Old 10th March 2006, 01:32 AM   #3
dfdye is offline dfdye  United States
dfdye's Avatar
If the transformer is 42VCT, then you can use the +/-21V and be right in the sweet spot with ~+/-30V.
Mmmmm. . . . . . Sweet. . . . . .
If it is just +42V, then you will have a little more work to do, and will probably either need to use a different transformer (unless you want to do some surgery on it!)
I think we just need a little more info on the transformer to really say if it will be useful.
43v SMPS for dual bridge mono LM4780 juan_caliente Chip Amps 45 2nd May 2010 10:37 PM
LM4780 dual mono -- boards jackinnj Swap Meet 1 1st October 2008 12:44 AM
AudioSector LM3875 dual mono classic kit. gychang Swap Meet 2 2nd August 2008 01:28 PM
AudioSector LM3875 dual mono premium kit. nodiak Swap Meet 1 16th October 2007 05:38 PM
AudioSector LM4780 Dual-Mono - questions/build log gongzero Chip Amps 3 22nd October 2006 02:43 PM
Page generated in 0.06332 seconds (77.40% PHP - 22.60% MySQL) with 10 queries
