| Chip Amps Amplifiers based on integrated circuits |
Argh, I had this post all typed up and it wouldn't let me post. I just now found the little "have you searched check box". I need heat sinks for my LM3875. I don't have access to spare parts. I need a place I can go and buy something and use it. I don't care if its an actual heat sink but I need a link and recommendation. This is my first DIY project and I don't have all the secret handshake knowledge of obscure sources of materials that we use for unintended uses etc. to find parts that no one else can get. I just need a heat sink and for this forum to let me post.
#2 |
Hi CJ Paul,
Looks like you succeeded in posting. These chips don't normally generate that much heat. I personally use 40 x 40 x 3mm aluminium angle for mine and many just use the metal case as a heatsink. A few use a block of copper or similar material. Computer CPU heatsinks are also often used. Then you could go to you local Electronics shop and buy a real heatsink. Conrad heatsinks seem to have a good reputation and I use them on my discrete amps. http://www.conradheatsinks.com/welcome.htm Hope this points you in the right direction. regards
Greg Erskine |
#3 |
Thanks for the reply. I assume 40x40 is the size of the "legs" of the angle iron and 3mm is the thickness? If so, what length do you use for each chip?
#4 |
Hi CJ Paul,
I have 2 x 300mm pieces on top of each other. See pictures here: http://www.briangt.com/gallery/nigc-erskine I have recently increased the number GC modules from 2 to 4 and the 2 pieces of angle now gets quite warm, not hot, after many hours. For testing purposes, I use 1 x 200 mm piece for 2 chips and have never had a problem. As with everything audio, YMMV because of PSU voltage, speakers used, construction methods and volume. Remember, having too much heatsink is not a problem. regards
Greg Erskine |
#5 |
Cool, that should get me started. Thanks!
| LM3875 Heat Sink Issues | cjv998 | Chip Amps | 16 | 23rd July 2007 10:21 AM |
| heat sink for UCD700? | pburke | Class D | 68 | 7th July 2006 05:40 AM |
| heat sink problem | k1jroth | Solid State | 12 | 24th March 2006 08:34 AM |
| DH-500 heat sink assembly | Dick West | Swap Meet | 2 | 13th April 2005 04:51 AM |
| How much heat sink is necessary? | rosss | Pass Labs | 11 | 23rd February 2003 06:23 AM |
| Page generated in 0.09013 seconds (66.73% PHP - 33.27% MySQL) with 10 queries |
