Old 7th March 2006, 01:07 PM   #1
roger-k is offline roger-k  Norway
Default RIAA with balanced output?
I want to build a RIAA-preamp with balanced output,
based on OP-amps.
Do you people know where I can find some schematics
or datasheets with any exemplifyes?
I have find many but not with balanced output.
Roger
Old 26th April 2010, 03:19 PM   #2
FdW is offline FdW  Netherlands
FdW's Avatar
Maybe this thread can help
Balanced input all DC coupled RIAA preamp
Frans de Wit
Old 26th April 2010, 04:46 PM   #3
FdW's Avatar
Frans de Wit
Oops, that's wrong, I misread 'input' for 'output', sorry
Old 26th April 2010, 05:00 PM   #4
based on OP-amps.
So you add a balanced line driver like a DRV-134 or SSM2142 or you could just use a dual opamp for each channel with one amp as an inverter. The gains need to be identical so don't forget the gain of the inverting amp is the ratio of the resistors but the non-inverting gain is that same ratio plus 1.
Check out the DRV or SSM datasheets for details using line driver chips.
Old 1st May 2010, 11:27 PM   #5
Yonzie is offline Yonzie  Denmark
You could use a TI OPA1632 differential opamp.
You can find a schematic on page 21 here (but I haven't checked if the amplification is 1x or something else to better suit the rest of the circuit):
http://focus.ti.com/lit/ug/slau288/slau288.pdf
Balanced XLR source RIAA Stee Analog Line Level 25 11th October 2008 10:59 AM
RIAA with balanced output? roger-k Analogue Source 19 17th March 2006 04:42 PM
OPA1632 for balanced RIAA preamp.? Ultima Thule Analogue Source 1 7th June 2004 09:06 PM
ono balanced output pamaz Pass Labs 6 3rd March 2004 11:20 PM
balanced output wuffwaff Solid State 14 16th January 2002 06:54 AM
Page generated in 0.08594 seconds (72.89% PHP - 27.11% MySQL) with 10 queries
