| Chip Amps Amplifiers based on integrated circuits |
I just hooked up my newly completed LM3886 amp based on Linkwitz's circuit that I cranked out while waiting for the transisitors for my LM4702 to come in. Falling firmly under the "DUH!!!" category for most of the people on this board, I am quite frankly astounded that such nice sound can come from such an amazingly simple package. Right now the parts are flowing all over my workbench, but I will be sure to post some pics when I get it in the purty case I am building. So far it seems perfectly suited for life as my dedicated iPod/computer amp in my office.
Thanks to everybody for help the offered, whether you know you helped or not!
#2 |
care to share on this ? building my first one. pcb schematics whatever? thanks
#3 |
This is a good site with everything you need.
http://hepso.dna.fi/misc/Ukram_Data.html Hope that works.... |
#4 |
The circuit I used was from
http://www.linkwitzlab.com/images/graphics/3886amp.gif but the PCB was a custom one that I have attached. There are some things I don't like about the board that I figured out after I sent the boards into be manufactured. For example, CS+ and CS- are in the wrong spot (they should be right next to the chip and after the V+ and V- inputs) and I didn't ground the nonconnected pins (though I fixed that by wiring p2p on the boards when I put them together. Also, though I put a feedback resistor part on the board, I put the resistor directly across the chip pins. The case isn't finished quite yet, but I will definitely post more pics when I have time to finish it up. It is, however, running strong in my workshop while I do stuff for work, and it sounds great. My Cheap-o Pioneers I bought in high school low these many years ago sound better than they have ever sounded (which is still pretty bad, but at least I have tunes in the shop ) I have hooked them up to my North Creek CM-77's for more testing, and the sound is really nice. I know these aren't the best reference monitors, but my budget (and my wife) hasn't allowed me to get much better than that yet! Here is the PCB, but I would recommend that a few modifications be made if anyone is interested in using the design. If anyone is interested, let me know and I will post a revision B. |
#5 |
This is a bad picture from my phone (which is the only digital camera I own
#6 |
Here is the revision2 PCB layout if anyone is interested. I took off the feedback resistor assuming that it would be mounted to the chip pins. I also moved the bypass caps, shrank the board a little, and ran a better ground plane that actually connects the loose pins this time!
David |
#7 |
hi dfdye,
Nice work. We are watching. Just a couple of points that I have read but not experimented with myself. 1. I don't think you need to worry about the NC pins. They can connect to anything or nothing. Connecting them to a ground plane does seem a nice thing to do though. Have you found it made a difference? 2. I noticed on the Linkwitz schematic that the mute resistor was a reasonably high value, limiting current. I have seem a few posts suggesting a higher current through the mute circuit is better. regards
Greg Erskine |
#8 |
dfdye,
What was the price/quantity for your pcbs you had made? Is single sided cheaper to get made? or is the advantage that you can etch it yourself? I'd like to design a little 3886 board similar to that for my first pcb. What software did you use? Any chance I could have the files to get me started?
#9 | |||
Thanks! This is definitely a learning experience. I have always relied on our electronics shop to do pcb stuff for me before I found this forum. I am amazed at how quickly you can pick it up! I am sure there is a ton I am doing wrong, but at least I am hafing fun messing things up! ![]() Quote:
) there can be issues. Good practice that I learned a long time ago was to tie all NC pins to ground if you can. Quote:
#10 | |||
The web page for the boards is: http://www.olimex.com/pcb/index.html One thing you will have to deal with is Faxing to Bulgaria. That was interesting. Quote:
Good Luck! |
| Another satisfied GainClone DIYer :) | Elkaid | Chip Amps | 9 | 21st September 2010 05:27 PM |
| Not satisfied with your guitar amp? LEGO! | Geek | Instruments and Amps | 7 | 2nd August 2009 10:43 PM |
| Really not satisfied with layout need advice | Yoshy | Chip Amps | 6 | 12th June 2009 04:57 PM |
| Are you satisfied with your system ? | aevus | Everything Else | 9 | 7th October 2004 07:18 PM |
| Page generated in 0.14435 seconds (75.23% PHP - 24.77% MySQL) with 11 queries |
