Old 7th March 2006, 02:23 AM   #1
Ipanema is offline Ipanema  Malaysia
Ipanema's Avatar
Default Balance LM3886 not working
Guys,
I have made this balance LM3886 as the schematic attached. The problem is both positve and negative output voltage goes to near VDD upon power ON. Found this schematic from instrumentation amplifier circuit.
What possibly went wrong with this circuit? Pls help.
Thanks.
Old 7th March 2006, 04:31 AM   #2
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Your schematic doesn't have VDD on it. You have used a non-polarized cap for C1?
Some pictures of your project would be helpful, to check the wiring, make sure all the caps are in the right way, no solder bridges, etc.
The power of Science compels you!
Old 7th March 2006, 04:56 AM   #3
Ipanema's Avatar
Hi Dcibel,
Sorry, the the positive supply is labelled as VCC instead of VDD while the negative suupply is VEE.
C1 (zobel) is Wima MKS2 non-polar.
I 've attached the layout. The red line is my jumper wire. Do you see anything wrong with the layout as well? I'll take picture of the board and post here tomorrow.
Thanks.
Old 7th March 2006, 04:57 AM   #4
Ipanema's Avatar
Layout
Old 7th March 2006, 05:03 PM   #5
DcibeL's Avatar
My thought is that the small track from pin 1 to pin 5 (VCC) that goes over pin 3 (output) is shorting to pin 3. Can you check this with a multimeter? Also check on your board that the track on pin 8 does not short to pin 9 or 10.
Old 9th March 2006, 12:37 AM   #6
Ipanema's Avatar
Hi Dcibel,
I have check through the board and nothing is shorting. Could it be that the the feedback resistor R10 is not physically grounded?
Anyone have tried this circuit before?
Thanks.
Old 9th March 2006, 01:20 AM   #7
DcibeL's Avatar
As far as I can tell the circuit should work. When one input is posotive, and the other is negative (balanced input), then the feedback of one chip will be opposite of the feedback of the other, so...I don't know it's hard to explain but it should work. You could test that the circuit works by doing a Spice simulation using a couple of op-amps. That is, provided your circuit design software does Spice simulations.
Normally for a balanced input, you would just apply one signal to the posotive input, and one to the negative. But I guess this way you get a larger output like a bridge configuration.
Help me balance SQ and SPL and weight for my sub eRiCdWoNg Subwoofers 6 25th February 2007 01:39 AM
Where to get balance controls? Glowbug Solid State 5 26th October 2006 08:06 AM
Quad balance ginsner Solid State 4 16th August 2006 08:04 PM
What is true balance? Aaron323 Solid State 8 5th January 2006 07:38 AM
Balance control 2Bak Pass Labs 4 11th July 2002 07:07 AM
Page generated in 0.09618 seconds (72.57% PHP - 27.43% MySQL) with 11 queries
