| Chip Amps Amplifiers based on integrated circuits |
Hi
I've been searching for information about DIY-Projects with the 7293 IC, when I found this interesting forum. I wonder if you an help me with a preamp solution. At the moment, I'm trying a little 2.1 Project with the 7293, using this circuit: http://home.s-planet.de/t.dauner/7293/ES7293-100.PDF The Layout is 95% that one from the data sheet: http://www.st.com/stonline/products/...re/ds/6744.pdf page 11 3 PCBs with 2 TDAs parallel each, the bass channel will be produced with an active crossover network. I want to use it with my pc, CD-player and my old FM tuner. First I wanted to use it without a preamp, using just a potentiometer for volume control ("passive preamp") But im not sure if they have enough power to drive the TDA and parallel the active crossover network for the Basschannel(48K input resistance). I'm also afraid that turning the potentiometer might affect the frequency response. So I decided to use a OP Buffer, like TL071, NE5534 or OPA627. I think about a solution like this: crossover network - TDAs CD-Player/PC - Op Buffer - Potentiometer- TDAs What I need now is a circuit for Buffer and Potentiometer. It should contain a low pass filter to prevent RF from entering the TDAs. I DONT need balance and bass/treble control. Any Ideas? Thanks, Stephan |
#2 |
I hope this is more visible:
############################### -> crossover -> TDAs cd-player/pc -> Op-Buffer -> Potentiometer -> ############################### -> TDAs |
#3 |
I cant download this
ES7293-100.PDF File from the mentioned link can you provide any alternate links thanks Ali |
| tda 7293 and tda 7294 help | sagarverma | Chip Amps | 84 | 19th May 2012 03:40 AM |
| Power Amp IC TDA 7293 | headsavers | Parts | 2 | 22nd September 2006 01:39 AM |
| Question about bridging TDA 7293 | Cro maniac | Chip Amps | 4 | 6th February 2004 09:10 PM |
| Appropriate components: LM 3886/ TDA 7293/ + | rick57 | Chip Amps | 1 | 23rd December 2003 09:03 PM |
| PA Amp with TDA 7293...Questions... | iCebReakEr409 | Solid State | 5 | 8th August 2002 08:59 PM |
| Page generated in 0.07471 seconds (70.99% PHP - 29.01% MySQL) with 10 queries |
