| Chip Amps Amplifiers based on integrated circuits |
I have been seeing alot lately about speaker protection and I do not have this in my LM4780 amp. Just wondering if this is a huge risk I am taking that I should remedy fast or not.
Also, Some of my speakers have built in protectors. Is this suffiecient or should I still be running pros on the amp itself?? Dominick
A real amateur enthusiast! |
#2 |
How many amplifiers have you fried by shorting the terminals or overloading the output stage? If = >1, then you might consider protection. If = >5, seriously consider it.
I for one, don't think it worth the effort, especially for a chipamp as economical to replace/repair as the LM-series.
Jesus loves you. |
#3 |
Well, I have fried one chip although I am not %100 sure why. So the speaker pro protects the chip??
I thought it protected the speaker?? Call me crazy!LOL *not trying to be sarcastic-I am really trying to understand* Dominick
#4 |
My chip amps are constantly powered on and so far I didn't experience any problems (for last two, three years). However, one needs to be certain that the source equipment does not produce any DC offset.
Whenever I change something with the equipment, making mods to the amps, connecting new sources or change PS, I always disconnect speakers from the amp first, and before connecting them back measure the DC offset. At one time I was experimenting with a preamp and that produced 24V DC at the speakers, but I acted quicly and it didn't damage anything. I got only once in trouble blowing two of my Triangle midwoofers ($250 ea.) but it happened with a different amp: the A75. The drivers I'm presently using are quite expensive ($800pc and 1000Euro/pc) but I still chose not to use any protection. You can check one of the older threads dealing with a subject: Amplifier and speaker protection circuits The chips are protected for output short and will not produce DC offset if one rail fails. So you don't really need a circuit to protect chips, if anything, you need something to protect the speakers.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 | |
Banned
Otherwise you wouldn't need an output cap when using single supply. |
#6 |
Another thing never mentioned in the data sheets is what will happen if one of the supply rails goes open (likely with fuse protection) or short to ground.
#7 | |
#8 |
And least one other forum member tried it as well: http://www.diyaudio.com/forums/showt...803#post229803
#9 |
Banned
Dominick22 -
I have been seeing alot lately about speaker protection and I do not have this in my LM4780 amp. Just wondering if this is a huge risk I am taking that I should remedy fast or not. Also, Some of my speakers have built in protectors. Is this suffiecient or should I still be running pros on the amp itself?? Dominick ------------------------------------------------- those spks that have protection yes theyre protected typical of spks protection is provided with polyswitches,fuses ...,etc cheers |
#10 |
Well , if we need to protect loadspeakers only , why not use a simple fuse ? It should blow much quicker than a loadspeaker , if current rating is chosen correctly...
| speaker protection | audiofan | Solid State | 0 | 19th February 2009 02:35 PM |
| speaker protection (OR) overload protection | myanmar | Solid State | 7 | 13th July 2006 08:21 AM |
| FS: Niles HDS-6L speaker selector w/ speaker protection. | Spasticteapot | Swap Meet | 0 | 27th May 2006 11:14 PM |
| Speaker Protection | senee | Solid State | 0 | 17th May 2005 06:53 AM |
| Page generated in 0.13558 seconds (77.33% PHP - 22.67% MySQL) with 10 queries |
